TPIC74100是一款开关模式稳压器,集成了用于电压模式控制的开关。借助外部元件(LC组合),器件可在宽输入电压范围内将输出调节至5 V±3%。
TPIC74100提供复位功能,可检测并指示5 -V输出导轨超出规定的公差范围。该复位延迟可通过REST引脚上的外部定时电容进行编程。此外,当输入电源轨V 驱动器低于预定的指定值(由A IN OUT )功能>引脚)。
TPIC74100具有频率调制方案,可最大限度地降低EMI。时钟调制器允许调制开关频率,以降低频带中的干扰能量。
5Vg输出是一个开关的5 V稳压输出,具有内部电流限制功能,可防止RESET在通电时产生断言电源线上的容性负载。该功能由5Vg_ENABLE引脚控制。如果此输出(5Vg输出)存在接地短路,则输出通过在斩波模式下工作进行自我保护。但是,在此故障情况下,这会增加V OUT 上的输出纹波电压。
Topology |
Vin (Min) (V) |
Vin (Max) (V) |
Vout (Min) (V) |
Vout (Max) (V) |
Switch Current Limit (Typ) (A) |
Duty Cycle (Max) (%) |
Switching Frequency (Min) (kHz) |
Switching Frequency (Max) (kHz) |
Iq (Typ) (mA) |
Features |
Iout (Max) (A) |
Operating Temperature Range (C) |
Rating |
Package Group |
TPIC74100-Q1 | TPIC74101-Q1 | TPS55065-Q1 | TPS55160-Q1 | TPS55162-Q1 | TPS55165-Q1 |
Buck/Boost | Buck/Boost | Buck/Boost | Buck/Boost | Buck/Boost | Buck/Boost |
1.5 | 1.5 | 1.5 | 3.6 | 3.6 | 2 |
40 | 40 | 40 | 36 | 36 | 36 |
5 | 5 | 5 | 5.7 | 5.7 | 5 |
5 | 5 | 5 | 9 | 9 | 12 |
1.5 | 1.5 | 1.5 | 3.5 | 3.5 | 3.5 |
99 | 99 | 99 | 99 | 99 | 99 |
330 | 285 | 330 | 2000 | 2000 | 2000 |
550 | 480 | 550 | 2000 | 2000 | 2000 |
0.1 | 0.1 | 0.1 | 0.015 | 0.015 | 0.015 |
Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification | Enable Light Load Efficiency Power Good Synchronous Rectification UVLO Fixed | Enable Power Good Synchronous Rectification UVLO Fixed | |
1 | 1 | 1 | |||
-40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
Automotive | Automotive | Automotive | Automotive | Automotive | Automotive |
HTSSOP | HTSSOP | HTSSOP | HTSSOP | HTSSOP | HTSSOP |
