DRA75x和DRA74x(Jacinto 6)信息娱乐应用处理器旨在满足现代信息娱乐系统汽车体验的强烈处理需求。
<该设备使原始设备制造商(OEM)和原始设计制造商(ODM)能够快速实施创新的连接技术,语音识别,音频流等。 Jacinto 6器件通过完全集成的混合处理器解决方案的最大灵活性带来高处理性能。这些器件还将可编程视频处理与高度集成的外设集合在一起。
可编程性由双核ARM Cortex-A15 RISC CPU提供,具有Neon™扩展,TI C66x VLIW浮点DSP内核和Vision AccelerationPac(带有一个或多个EVE)。 ARM允许开发人员将控制功能与DSP和协处理器上编程的其他算法分开,从而降低系统软件的复杂性。
此外,TI还为ARM,DSP提供了一整套开发工具。和EVE协处理器,包括C编译器和用于查看源代码的调试接口。
DRA75x和DRA74x Jacinto 6处理器系列符合AEC-Q100标准。
特性
- Architecture Designed for Infotainment Applications
- Video, Image, and Graphics Processing Support
- Full-HD Video (1920 × 1080p, 60 fps)
- Multiple Video Input and Video Output
- 2D and 3D Graphics
- Dual ARM® Cortex®-A15 Microprocessor Subsystem
- Up to two C66x Floating-Point VLIW DSP
- Fully Object-Code Compatible With C67x and C64x+
- Up to Thirty-two 16 x 16-Bit Fixed-Point Multiplies per Cycle
- Up to 2.5MB of On-Chip L3 RAM
- Level 3 (L3) and Level 4 (L4) Interconnects
- Two DDR2/DDR3/DDR3L Memory Interface (EMIF) Modules
- Supports up to DDR2-800 and DDR3-1066
- Up to 2GB Supported per EMIF
- Dual ARM® Cortex®-M4 Image Processing Units (IPU)
- Up to Two Embedded Vision Engines (EVEs)
- IVA Subsystem
- Display Subsystem
- Display Controller With DMA Engine and up to Three Pipelines
- HDMI™ Encoder: HDMI 1.4a and DVI 1.0 Compliant
- Video Processing Engine (VPE)
- 2D-Graphics Accelerator (BB2D) Subsystem
- Dual-Core PowerVR® SGX544 3D GPU
- Three Video Input Port (VIP) Modules
- Support for up to 10 Multiplexed Input Ports
- General-Purpose Memory Controller (GPMC)
- Enhanced Direct Memory Access (EDMA) Controller
- 2-Port Gigabit Ethernet (GMAC)
- Sixteen 32-Bit General-Purpose Timers
- 32-Bit MPU Watchdog Timer
- Five Inter-Integrated Circuit (I2C) Ports
- HDQ™/1-Wire® Interface
- SATA Interface
- Media Local Bus (MLB) Subsystem
- Ten Configurable UART/IrDA/CIR Modules
- Four Multichannel Serial Peripheral Interfaces (McSPI)
- Quad SPI (QSPI)
- Eight Multichannel Audio Serial Port (McASP) Modules
- SuperSpeed USB 3.0 Dual-Role Device
- Three High-Speed USB 2.0 Dual-Role Devices
- Four MultiMedia Card/Secure Digital/Secure Digital Input Output Interfaces (MMC™/SD®/SDIO)
- PCI-Express® 3.0 Subsystems With Two 5-Gbps Lanes
- One 2-lane Gen2-Compliant Port
- or Two 1-lane Gen2-Compliant Ports
- Dual Controller Area Network (DCAN) Modules
- Up to 247 General-Purpose I/O (GPIO) Pins
- Real-Time Clock Subsystem (RTCSS)
- Device security features
- Hardware Crypto accelerators and DMA
- Firewalls
- JTAG® lock
- Secure keys
- Secure ROM and boot
- Power, Reset, and Clock Management
- On-Chip Debug With CTools Technology
- 28-nm CMOS Technology
- 23 mm × 23 mm, 0.8-mm Pitch, 760-Pin BGA (ABC)
All trademarks are the property of their respective owners.
参数 与其它产品相比 DRAx 信息娱乐系统 SOC
Arm CPU |
Arm MHz (Max.) |
DSP |
DSP MHz (Max) |
Graphics Acceleration |
Co-Processor(s) |
Display Options |
Hardware Accelerators |
EMIF |
DRAM |
Other On-Chip Memory |
EMAC |
Video Input Ports |
Serial I/O |
MMC/SD |
PCIe |
USB |
McASP |
Security Enabler |
DRA750 | DRA756 |
2 ARM Cortex-A15 | 2 ARM Cortex-A15 |
1000 | 1500 |
2 C66x | 2 C66x |
750 | 750 |
1 2D 2 3D | 1 2D 2 3D |
2 Dual ARM Cortex-M4 | 2 ARM Cortex-M4 |
1 HDMI OUT 3 LCD OUT | 1 HDMI OUT 3 LCD OUT |
1 Image Video Accelerator 2 Viterbi Decoder Audio Tracking | 2 EVE 1 Image Video Accelerator 2 Viterbi Decoder Audio Tracking |
2 32-bit | 2 32-bit |
DDR2-800 DDR3-1066 DDR3L-1066 | DDR2-800 DDR3-1066 DDR3L-1066 |
512 KB | 2.5 MB |
10/100/1000 2-port 1Gb switch | 10/100/1000 2-port 1Gb switch |
10 | 10 |
CAN I2C SPI UART USB | CAN I2C SPI UART USB |
1x SDIO 4b 1x SDIO 8b 1x UHSI 4b 1x eMMC 8b | 1x SDIO 4b 1x SDIO 8b 1x UHSI 4b 1x eMMC 8b |
2 PCIe Gen2 | 2 PCIe Gen2 |
1 USB3.0 3 USB2.0 | 1 USB3.0 3 USB2.0 |
8 | 8 |
Cryptographic acceleration Debug security Device identity Secure boot Secure storage Trusted execution environment | Cryptographic acceleration Debug security Device identity Secure boot Secure storage Trusted execution environment |
无样片 | 无样片 |
