数据: 具有 20V 过压保护功能的TS5USBC402双路 2:1 USB 2.0 多路复用器/多路信号分离器或单端交叉开关 数据表 (Rev. A)
TS5USBC402是一种双向低功耗双端口高速USB 2.0模拟开关,具有针对USB Type-C™系统的集成保护功能。该器件配置为双路2:1或1:2开关,并经过了优化,能够应对USB Type-C™系统中的USB 2.0 D +/-线路。
TS5USBC402在I /O引脚上的保护功能可承受高达20V的电压,并配备自动关闭电路来保护开关后面的系统组件。
TS5USBC402采用小型12引脚DSBGA封装,使其成为移动应用和空间受限型应用中的杂音问题。中对于高效率,高电源密度和稳健性的需求。
所有商标均为其各自所有拥有者。
Device Type |
Number of Channels (#) |
Configuration |
VCC (Min) (V) |
VCC (Max) (V) |
Ron (Typ) (Ohms) |
Input/Ouput Voltage (Min) (V) |
Input/Ouput Voltage (Max) (V) |
ICC (Max) (uA) |
Bandwidth (MHz) |
ESD HBM (Typ) (kV) |
Features |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
Pin/Package |
TS5USBC402 | TS3USB3000 | TS3USB3031 | TS3USB3200 | TS3USBCA4 | TS5USBC400 | TS5USBC41 |
USB/MHL Switch | USB/MHL Switch | USB/MHL Switch | USB/MHL Switch | Multiplexer | USB/MHL Switch | |
2 | 2 | 2 | 2 | 3 | 2 | 2 |
Dual 2:1 | 2:1 SPDT | 3:1 | 2:1 SPDT | Multiplexer with MIC/AGND | Dual 2:1 | Dual 2:1 |
2.3 | 2.7 | 2.5 | 2.7 | 2.4 | 2.3 | 2.3 |
5.5 | 4.3 | 4.3 | 4.3 | 5.5 | 5.5 | 5.5 |
5.6 | 4.6 | 4.5 | 4.6 | 5 | 5.6 | 5.6 |
0 | 0 | 0 | 0 | 0 | 0 | 0 |
20 | 3.6 | 3.6 | 3.6 | 5.5 | 18 | 18 |
100 | 50 | 40 | 70 | 70 | 100 | 22 |
1200 | 6100 | 6500 | 5500 | 500 | 1200 | 1200 |
2 | 3.5 | 2 | 3.5 | 2 | 2 | 2 |
20V Over Voltage Protection |
USB 2.0 Mobile High-Definition Link (MHL) Over-Voltage Tolerance (OVT) Current Leakage Protection Logic Controlled (Output Enabled) |
USB 2.0 Mobile High-Definition Link (MHL) Over-Voltage Tolerance (OVT) Current Leakage Protection Flexible Power Control Logic Controlled (Output Enabled) |
SBU Multiplexer with MIC/AGND | 16V Over Voltage Protection |
20V Over Voltage Protection Very low power consumption |
Catalog | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
-40 to 85 0 to 70 |
-40 to 85 | -40 to 85 | -40 to 85 | 0 to 70 |
-40 to 85 0 to 70 |
-40 to 85 0 to 70 |
DSBGA | UQFN | WQFN | UQFN | UQFN | DSBGA | DSBGA |
See datasheet (DSBGA) | 10UQFN: 3 mm2: 2 x 1.5(UQFN) | 12WQFN: 3 mm2: 1.8 x 1.8(WQFN) | 16UQFN: 5 mm2: 1.8 x 2.6(UQFN) | 16UQFN: 5 mm2: 1.8 x 2.6(UQFN) | See datasheet (DSBGA) | See datasheet (DSBGA) |
12DSBGA | 10UQFN | 12WQFN | 16UQFN | 16UQFN | 12DSBGA | 12DSBGA |
