TSU5611被设计成能够与手机UART,USB和通过微型USB连接器与外部设备连接的音频芯片进行连接。这个开关特有阻抗检测功能用以识别通过微型USB端口的DP和DM连接的多种配件。当一个配件插入到微型USB端口时,这个开关使用侦测机制以识别这个配件(详细信息请参考状态机期刊)。然后它将切换到合适的频道 - 数据,音频,或者UART。
TSU5611有一个I2C接口用于与手机基带或者应用设备处理器进行通信。当微型USB接口侦测到任何插入设时,一个中断会产生。当设备拔出时,产生另外一个中断。
Device Type |
Number of Channels (#) |
Configuration |
VCC (Min) (V) |
VCC (Max) (V) |
Ron (Typ) (Ohms) |
Input/Ouput Voltage (Min) (V) |
Input/Ouput Voltage (Max) (V) |
ICC (Max) (uA) |
Bandwidth (MHz) |
ESD HBM (Typ) (kV) |
Features |
Rating |
Operating Temperature Range (C) |
Package Group |
Package Size: mm2:W x L (PKG) |
Pin/Package |
TSU5611 | BQ24392 | BQ24392-Q1 | TSU5511 | TSU6111 | TSU6111A | TSU6712 | TSU6721 | TSU8111 |
USB/MHL Switch | USB/MHL Switch | USB/MHL Switch | USB/MHL Switch | USB/MHL Switch | USB/MHL Switch | USB/MHL Switch | USB/MHL Switch | |
2 | 2 | 1 | 2 | 2 | 2 | 2 | 2 | 2 |
1:3 SP3T | 1:1 SPST | 1:1 SPST | 1:3 SP3T | 1:2 SPDT | 1:2 SPDT | 1:4 SP4T | 1:3 SP3T | 1:2 SPDT |
2.8 | 4.75 | 4.75 | 2.8 | 3 | 3 | 3 | 3 | 1.65 |
6.7 | 5.25 | 5.25 | 6.7 | 6.5 | 6.5 | 6.5 | 6.5 | 6.5 |
4.5 | 8 | 6 | 4.5 | 8 | 8 | 8 | 6 | 8 |
0 | 0 | -1.3 | 0 | 0 | -0.8 | -1.5 | 0 | |
3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | |
See data sheet | 250 | 115 | 70 | 75 | 75 | 600 | 155 | 150 |
830 | 920 | 1000 | 830 | 920 | 920 | 510 | 510 | 820 |
1.5 | 4 | 4 | 2 | 2 | 5 | 1.5 | 4 | 12 |
USB 2.0 Audio Switch (Negative Rail Capability) Integrated LDO Impedance Detection |
USB 2.0 BCv1.2 Charger Detection |
USB 2.0 UART Audio Switch (Negative Rail Capability) Click-Pop Reduction Charging Capability I2C Interface Impedance Detection |
USB 2.0 UART BCv1.1 Charger Detection I2C Interface JIG and BOOT Support Attach and Detach Interrupt Surge Protection |
Audio Switch (Negative Rail Capability) Charging Capability I2C Interface JIG and BOOT Support Impedance Detection |
USB 2.0 UART Audio Switch (Negative Rail Capability) ID Bypass Switch Charging Capability BCv1.2 Charger Detection I2C Interface JIG and BOOT Support Impedance Detection Attach and Detach Interrupt |
USB 2.0 Integrated Single-Cell Charger BCv1.1 Charger Detection Impedance Detection Thermal Regulation and Shutdown |
Catalog | Catalog | Automotive | Catalog | Catalog | Catalog | Catalog | Catalog | Catalog |
-40 to 85 | -40 to 85 | -40 to 125 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
DSBGA | UQFN | UQFN | DSBGA | UQFN | UQFN | DSBGA | DSBGA | DSBGA |
See datasheet (DSBGA) | 10UQFN: 3 mm2: 2 x 1.5(UQFN) | 10UQFN: 3 mm2: 2 x 1.5(UQFN) | See datasheet (DSBGA) | 16UQFN: 5 mm2: 1.8 x 2.6(UQFN) | 16UQFN: 5 mm2: 1.8 x 2.6(UQFN) | See datasheet (DSBGA) | See datasheet (DSBGA) | See datasheet (DSBGA) |
20DSBGA | 10UQFN | 10UQFN | 20DSBGA | 16UQFN | 16UQFN | 25DSBGA | 25DSBGA | 20DSBGA |
