TMUX6104是一款现代互补金属氧化物半导体(CMOS)模拟多路复用器.TMUX6104提供4:1单端开关功能,并且使用双电源(±5V至±18V)和单电源(10V至36V)供电时均能正常运行。此外,该器件在由对称电源(如V DD = 12V,V SS = -12V)和非对称电源(如V DD = 12V,
V SS = -5V)供电时也能保证优异性能所有数字输入均具有兼容TTL逻辑的阈值。当器件在有效电源电压范围内运行时,这些阈值可确保TTL和CMOS逻辑兼容性。
TMUX6104具有非常低的导通和关断泄漏电流以及超低的电荷注入,因此该器件可用于高精度测量应用中,低功耗是一个关键问题。当开关处于OFF位置时,该器件还可通过阻断到达电源的信号电平来提供出色的隔离能力。电源电流低至17μA,使得该器件可用于便携式应用中,中对于效率,高电源密度和稳健性的需求。
所有商标均为其各自所有者的财产。
Configuration |
Number of Channels (#) |
Power Supply Type |
Vss (Min) (V) |
Vss (Max) (V) |
Vdd (Min) (V) |
Vdd (Max) (V) |
Ron (Typ) (Ohms) |
Bandwidth (MHz) |
Rating |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
Supply Range (Max) |
Ron (Max) (Ohms) |
Input/Output Continuous Current (Max) (mA) |
Supply Current (Typ) (uA) |
Supply Current (Max) (uA) |
Features |
OFF-state leakage current (Max) (µA) |
ON-state leakage current (Max) (µA) |
Input/Output ON-state Capacitance (Typ) (pF) |
Input/Output OFF-state Capacitance (Typ) (pF) |
ESD Charged Device Model (kV) |
ESD HBM (kV) |
VIL (Max) (V) |
VIH (Min) (V) |
TMUX6104 | MUX36D04 | MUX36D08 | MUX36S08 | MUX36S16 |
4:1 | 4:1 | 8:1 | 8:1 | 16:1 |
1 | 2 | 2 | 1 | 1 |
Single Dual | Single Dual | Single Dual | Single Dual | Single Dual |
-18 | -18 | -18 | -18 | -18 |
-5 | -5 | -5 | -5 | -5 |
10 | 10 | 10 | 10 | 10 |
36 | 36 | 36 | 36 | 36 |
125 | 125 | 125 | 125 | 125 |
400 | 500 | 500 | 500 | 500 |
Catalog | Catalog | Catalog | Catalog | Catalog |
-40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) 16WQFN: 16 mm2: 4 x 4(WQFN) | 32QFN: 16 mm2: 4 x 4(QFN) 28SOIC: 184 mm2: 10.3 x 17.9(SOIC) 28TSSOP: 62 mm2: 6.4 x 9.7(TSSOP) 32WQFN: 25 mm2: 5 x 5(WQFN) | 16TSSOP: 32 mm2: 6.4 x 5(TSSOP) 16WQFN: 16 mm2: 4 x 4(WQFN) | 32QFN: 16 mm2: 4 x 4(QFN) 28SOIC: 184 mm2: 10.3 x 17.9(SOIC) 28TSSOP: 62 mm2: 6.4 x 9.7(TSSOP) 32WQFN: 25 mm2: 5 x 5(WQFN) |
TSSOP | TSSOP WQFN | QFN SOIC TSSOP WQFN | TSSOP WQFN | QFN SOIC TSSOP WQFN |
250 | 430 | 430 | 430 | 430 |
30 | 30 | 30 | 30 | |
17 | 45 | 45 | 45 | 45 |
27 | 62 | 62 | 62 | 62 |
Dual supply Break-before-make | Dual supply Break-before-make | Dual supply Break-before-make | Dual supply Break-before-make | Dual supply Break-before-make |
0.0019 | 0.0045 | 0.0019 | 0.0045 | |
0.0033 | 0.0053 | 0.0033 | 0.0053 | |
5 | 6.7 | 8.7 | 9.4 | 13.5 |
1.6 | 2.4 | 2.1 | 2.4 | 2.1 |
0.5 | 0.5 | 0.5 | 0.5 | 0.5 |
2 | 2 | 2 | 2 | 2 |
0.8 | 0.8 | 0.8 | 0.8 | 0.8 |
2 | 2 | 2 | 2 | 2 |
