Intel Bay Trail J1900 CPU with dual eDP, 2*COM, 2*Mini-PCIe, DC 12V Input
规格
General | |
CPU | Intel® Bay Trail J1900 CPU, Quad-core, up to 2.42 GHz, TDP 10W |
Chipset | Null |
Memory | Up to 8 GB DDR3L 1333 MHz, 1*SO-DIMM |
Storage | 1*SATA 2.0, 1*mSATA |
Expansion Interface | 2*Mini-PCIe (1*mSATA Supported, 1*Wifi/3G/4G Supported) |
BIOS | AMI UEFI BIOS |
System | Windows 7/8/10, Linux, Android |
I/O Interface | |
Serial Port | 2*RS232 (COM3 TTL optional) |
USB | 1*USB 3.0, 8*USB 2.0 (4*on rear I/O, 5*header) |
Ethernet | 1*Realtek® PCI-E LAN for 1000Mbps |
Audio |
Realtek® ALC662 5.1 channel HDA Codec, supports MIC/Line-out Ports 1*Amplifer |
PS/2 | 1*PS/2 header (Keyboard and Mouse Supported) |
Parallel Port | 1*LPT |
GPIO | 8 programmable GPIO |
Feature Interface | Null |
Display | |
Display Interface |
1*VGA: max resolution up to 2560*1600@60Hz 1*eDP: max resolution up to 1920*1200@60Hz 1*LVDS/eDP: LVDS, Dual channel 24 bit, max resolution up to 1920*1200@60Hz eDP, max resolution up to 1920*1200@60Hz |
Multiple Display | Dual |
Mechanical & Environment | |
Dimension | Mini-ITX, 170*170mm |
Power Input | DC 12V |
Temperature | Operation: 0℃~60℃, Storage: -25℃~75℃ |
Relative Humidity | Operation: 10%~90%, Storage: 5%~95%, non-condensing |
举报投诉
嵌入式主板
7文章
6066浏览量
34664 -
安卓
5文章
2094浏览量
54909 -
信步科技
5文章
263浏览量
7024
信步科技SV1a-H1116P规格英文版
Mbps LAN
With SVIO support SV-M6 I/O Module to extend COM/USB/PCI
Supports dual display of VGA
信步科技SV3b-38626规格英文版
, 1*Wifi+3G/4G)
Supports triple display of VGA, HDMI and LVDS/eDP
3.5'' (146*105mm)
规格
信步科技SV1-H2726C规格英文版
H270 chipset
Double-layer Rear I/O which can expand to 18*COM and 18*USB (use SV-M5 I/O Extension
信步科技SV1-19016EP规格英文版
Intel Bay Trail J1900 CPU, 6*COM, supports dual display of 2*eDP, with Cash Drawer and Touch Panel Control, DC 12V or ATX Input.
Supports Intel Bay Trail J1900 CPU
6*COM, 8*USB, 1*1000 Mbps LAN
1*VGA, 1*VGA/eDP, 1*LVDS/eDP, Supports dual display of 2*eDP
Supports Cash Drawer Control port (RJ11) and Touch Panel Control header
Supports DC 12V or ATX Input (optional)
信步科技SV1a-19012EP处理器规格
ntel Bay Trail J1900处理器, 2*COM, 2*Mini-PCIe, 支持双eDP显示, DC12V供电
采用Intel Bay Trail J1900处理器
提供2*COM, 9*USB, 1*千兆LAN
提供1*VGA, 2*eDP, 支持双eDP显示
提供2*Mini-PCIe (支持1*mSATA, 1*Wifi/3G/4G)
薄型Mini-ITX, 板身厚度≤17mm
信步科技SV1-H1126C规格英文版
chipset
Double-layer Rear I/O which can expand to 18*COM and 18*USB (use SV-M5 I/O Extension Modules
