企业号介绍
全部
  • 全部
  • 产品
  • 方案
  • 文章
  • 资料
  • 企业
上海屹持光电技术有限公司
红外观察仪、飞秒激光器、太赫兹相机、太赫兹光谱仪
618 内容数 10w+ 浏览量 27 粉丝
sappire 蓝宝石晶体窗片
型号: sappire
--- 产品详情 ---
For the past 15 years single crystal sapphire has been at the cutting edge of semiconductor technology.
A combination of unique chemical, physical, optical and mechanical properties make sapphire the best choice for a broad spectrum of laboratory and industrial applications.
• Chemical resistance.
Sapphire is highly inert and resistant to attack in most process environments including hydrofluoric acid and the fluorine plasma applications commonly found in semiconductor wafer processing (NF3, CF4).
• Mechanical properties.
Sapphire is characterized by high toughness and solidity, and demonstrates excellent resistance in different environments ranging from cryogenic to over 1500°C. Due to this characteristics combined with chemical stability sapphire is widely used in medicine: endoscope and probe lenses, needles for thermal treatment of tumors, scalpels etc.
• Electrical properties.
Sapphire provides a high, stable dielectric constant with the electrical insulation required for LED, RF and microwave applications.
• Optical transmission.
Sapphire is characterized by high transmission in the range of UV to near IR. Given the chemical stability, high temperature and high pressure resistance sapphire is the preferred choice for window / viewport applications in high performance vacuum systems, furnaces, deep sea cameras, fire alarm systems etc.
• Surface properties.
Sapphire can be polished to very high flatness and smoothness for substrate applications and precision mechanical components.
• Thermal properties.
With a melting point over 2000°C, and high thermal conductivity sapphire is often used in many harsh process environments.
• Wear properties.
With high hardness and transparency, sapphire is used for scratch proof windows in high wear applications and for precision mechanical components.
Basic properties
Crystallline structure
Hexagonal
a = b = 4.77 Å
c = 13.04
Melting point:
2040°С
Thermal expansion index:
6,7 х 10-6 С parallel to С-axis
Conductivity
46.06 W/m °K at 0°C
Specific resistivity:
5,0 х 10-6 С perpendicular to С-axis
Dielectric Constant
average 11.5 (parallel to C-axis)
Density
3,98 g/ cm3
Compressive Strength
2 GPa
Young Modulus
3.6x104 – 4.4x104
Flexural Strength
35-39 daN/ mm2
Tensile Strength
~400 MPa (at approx. 25°C)
Poisson’s Ratio
0.28-0.33
Hardness
9 mohs
1800 Knoop parallel to c-axis
2200 Knoop perpendicular to c-axis
Refraction Index
No: 1.768 (c-axis)
Ne: 1.760 (c-axis)
Birefringence
(No-Ne) 0.008
Sapphire Transmission
Products
Sapphire ingots for LED, RF and optical applications
Diameter/Width
5-220 mm
Thickness/Length
25 – 500 mm
Orientation
C (0001), M (1010), A (1120), R (1102)
Surface quality
As-cut, fine-ground
Ends/Edge Quality
As-cut, fine-ground
Sapphire tubes, capillaries and nozzles for mechanical and optical applications: laboratory equipment, semiconductor equipment, optical systems (CVD, plazma reactors, UV treatment of substances, protective sheaths for thermocouples etc.)
Sapphire crucibles for laboratory and semiconductor equipment
Sapphire needles for medical treatment.
Inner Diameter
0.6 - 30 mm
Outer Diameter
2 - 50 mm
Length
Up to 600 mm
Orientation
Random, C
Surface quality
As-grown, fine-ground, 80/50 per MIL-0-13830
Ends/Edge Quality
As-cut
Sapphire substrates for LED and RF applications
Diameter
50.8 – 160mm
Thickness
0.3 – 5 mm
Orientation
Surface quality
EPI-polished (Ra<0.5 nm) suitable for epitaxial growth
Sapphire windows and viewports for UV, visible and near-IR applications (semiconductor equipment, scanners, laser systems, fire alarm systems, deep sea cameras)
Diameter
1-240 mm
Thickness
>/=0.15 mm
Orientation
Random, M (1010), A (1120), R (1102), C (0001)
Flatness
4 λ per inch
Parallelism
<0.5 - 3 angular minutes
Chamfer
< /=0.1 - 0.5 mm x 45+/-5 deg
Surface quality
80/50, 60/40, 40/20, 20/10. or 10/5 per MIL-0-13830
Sapphire rods and blanks for LED, RF, optical, mechanical and medical applications
Diameter
1-300 mm
Thickness
>/=0.15 mm
Orientation
Surface quality
As-cut, fine-ground
为你推荐
  • SSFS飞秒激光孤子自频移波长调谐技术2024-07-02 09:17
    SSFS孤子自频移飞秒激光波长调谐模块利用SSFS孤子自频移现象(Soliton self-frequency shift ),允许用户在近红外范围内对飞秒激光进行波长调谐。通常,来自固定波长掺铒飞秒光源的孤子可以从1550 nm范围调谐到2100 nm波长。通过改变输入光功率,可以很容易地调谐输出波长。波长偏移输出信号保持相干性和线性极化。模块完全即插即用
    2166浏览量
  • 1.5μ超紧凑型单次自相关仪正式上市2024-06-17 16:08
    µ-ROC紧凑型单次自相关仪现已推出 1.5 µm新版本,光谱范围覆盖1300-1700nm,专用于掺铒飞秒激光器。至此µ-ROC已经可以覆盖传统800nm、1um、1.5um波段,用户可以根据自身需求灵活选择。µ-ROC同样配备STAR Software专用软件,用户终身可以通过自动更新轻松免费地访问最新软件版本。
    1567浏览量
  • 近距离了解中红外可调谐光纤飞秒激光器 Femtum Ultratune 3400性能2024-06-17 14:26
    中红外可调谐光纤飞秒激光器UltraTune 3400是一款商业中红外超快激光器,其结构紧凑、免维护和可调谐激光系统是科学研究的理想工具。
    2324浏览量
  • 可输出不同偏振太赫兹波的光电导天线2024-05-14 11:21
    屹持光电推出的大面积光电导天线辐射源,具有不同的极化类型,并且具有激发面积大,转换效率高的优点。该系列太赫兹光电导天线最显著的特点是:除了通常的线性极化外,还可以产生径向或者方位偏振的太赫兹辐射。径向极化辐射特别适合比如使用线波导进行传输的应用。用飞秒激光脉冲激发的光电导发射器是广泛使用的单周期太赫兹(THz)辐射脉冲源。通过应用交叉电极几何形状,可以显著提
    2107浏览量
