--- 数据手册 ---
--- 产品详情 ---
General Description
The RZC6291 is a current mode boost DC-DC converter. Its PWM circuitry with built-in 0.2Ω power MOSFET make this regulator highly power efficient. The internal compensation network also minimizes as much as 6 external component counts. The non-inverting input of error amplifier connects to a 0.6V precision reference voltage and internal soft -start function can reduce the inrush current.
The RZC6291 is available in the SOT23-6L package and provides space-saving PCB for the application fields.
Features
⚫ Adjustable Output up to 12V
⚫ Internal Fixed PWM frequency: 1.2MHz
⚫ Precision Feedback Reference Voltage: 0.6V
⚫ Internal 0.2Ω, 2A, 18V Power MOSFET
⚫ Shutdown Current: 0.1μA
⚫ Over Temperature Protection
⚫ Adjustable Over Current Protection: 0.5A ~ 2.5A
⚫ Package: SOT23-6L
Applications
⚫ Chargers
⚫ LCD Displays
⚫ Digital Cameras
⚫ Handheld Devices
⚫ Portable Products
为你推荐
RZC 瑞之辰科技 RZC5391Q 芯片2025-05-28 14:28
产品型号:RZC5391Q -
RZC 瑞之辰科技 RZC6622 芯片2025-05-28 14:25
产品型号:RZC6622 -
RZC 瑞之辰科技 RZC6291 芯片2025-05-28 14:14
产品型号:RZC6291 -
RZC 瑞之辰科技 RZC6116 芯片2025-05-28 14:10
产品型号:RZC6116 -
RZC 瑞之辰科技 MPJYDA020BA-2699-A1 传感器2025-05-28 13:57
产品型号:MPJYDA020BA-2699-A1 精度:±1% FS 压力类型:绝压 测量技术:MEMS 测量介质:气体;液体;腐蚀性的 输出信号:I²C -
RZC 瑞之辰科技 MPNYDA650KP-3522-01 压力传感器2025-05-28 13:36
产品型号:MPNYDA650KP-3522-01 产品类型 :传感器 (Transducer) 压力类型:绝压 测量介质:气体;液体 输出信号:I²C -
RZC 瑞之辰科技 MPJYDA011BA-2699 传感器2025-05-28 13:31
产品型号:MPJYDA011BA-2699 工作电压:5±0.05V 输出信号:0.5~4.5(10~90%Vcc) 压力量程:1~11Bar A(可定制) 爆破压力:4Mpa G 存储温度:-40~150℃
泵类流体设备压力监测:瑞之辰破解狭小空间与介质腐蚀痛点2026-08-27 13:23
终于找到!瑞之辰压力传感器适配狭小管路,可抗流场扰动2026-08-26 11:35
一颗压力传感器,如何决定一台工业泵的 “稳定感”?2026-08-25 14:19
泵类设备量产老翻车?瑞之辰解析压力传感器选型5大误区2026-08-24 11:51
既要又要还要且要?瑞之辰压力传感器提供压力监测解决方案2026-08-20 11:04
瑞之辰精密传感:狭小复杂工况,考验压力传感器实力2026-08-19 13:42
储能液冷微管路,适合选用什么微型压力传感器?2026-08-13 13:21
精密传感国产替代提速:瑞之辰压力传感方案助力企业降本增效2026-08-12 15:45
3个进口传感器替代难点,国产传感器如何解决?2026-08-11 10:45
狭小空间+复杂工况约束,瑞之辰微型压力传感如何实现可量产的精密监测2026-08-10 13:14
