企业号介绍
全部
  • 全部
  • 产品
  • 方案
  • 文章
  • 资料
  • 企业
禾洛半导体
禾洛半导体始创于1983年,专注于IC烧录与IC测试整体解决方案,承袭自 Hilosystems (河洛半导体)四十年技术底蕴。
6 内容数 8.4k 浏览量 1 粉丝
禾洛ALL-200工程型万用烧录器 - 半导体芯片烧录-产品型录英文版
型号: 禾洛ALL-200 工程型/量产型 万用IC烧录器/编程器
--- 产品参数 ---
  • 支援IC种类 支持MCU、Flash、EEPROM、FPGA、CPLD等。
  • 封装覆盖 兼容DIP至BGA、WLCSP等所有主流封装形式。
  • 界面清晰 流程状态同屏实时显示,直观掌控各座状况。
  • 核心架构 16位超频核心,搭载FPGA/CPLD,控制高速精准。
  • 驱动系统 56组精密驱动线路,信号高速、低噪、稳定。
  • 兼容范围 全面支持市面95%以上MCU,为量产首选。
--- 产品详情 ---
Product attributes of Heluo ALL-200 engineering
Product Features
Feature 1: Reliable programming performance
Independent research and development: Deep collaboration between software and hardware, ensuring stable and efficient programming of large-capacity ICs.
Intelligent protection: Full-pin automatic detection effectively prevents reverse insertion and poor contact.
Feature 2: Wide chip compatibility
Supported IC types: Supports a full range of chips including MCU/MPU, NOR/NAND Flash, EEPROM, SPI memory, FPGA, CPLD, and more.
Package coverage: Compatible with all mainstream package types including DIP, SDIP, SOP, SSOP, TSOP, PLCC, QFP, QFN, SON, BGA, and WLCSP.
Feature 3: Excellent quality of burner base
Durable: High-quality adapter board significantly extends the lifespan of the burner base.
Flexible expansion: Simply replace the corresponding base plate to accommodate new chips, offering strong scalability.
Feature 4: Convenient software operation
Clear interface: Real-time display of process status on the same screen, allowing intuitive control over the status of each seat.
Support Timeliness: The driver and support software are updated weekly to ensure rapid adaptation to new products.
product attributes
The ultra-high clock core circuit design significantly reduces the programming time of new-generation high-capacity memory ICs. The precise pin drive circuit provides high-speed, low-noise, accurate, and stable programming signals, meeting the programming requirements of special IC types, including high-speed and low-voltage types.
Core architecture: 16-bit overclocking core, equipped with FPGA/CPLD, for high-speed and precise control.
Processing performance: Ultra-high clock design significantly reduces the programming time for large-capacity chips.
Drive system: 56 sets of precision drive circuits, ensuring high-speed, low-noise, and stable signals.
Compatible range: Fully supports over 95% of MCUs on the market, making it the preferred choice for mass production.
Voltage support: Supports high-speed programming down to 1.8V, meeting the needs of special chips.
Hilo ALL-200 engineering/mass production universal IC burner/programmer - supports all types of chips such as MCU, Flash, FPGA, etc
为你推荐
  • Hilo_ ALL-200G_IC烧录器万用型_支持各类IC_USB2.0_产品型录2026-07-21 16:59
    产品型号:Hilo_ ALL-200G_IC烧录器万用型_USB 支援 IC 种类:MCU/MPU、SPI Memory、NOR/NAND 等 支援封装种类:DIP、SDIP、SOP、SSOP、TSOP、PLCC等 支援 IC 脚数:8 pins ~ 300 pins 烧录座:8 个烧录座转接板(HD-xxx-xxx / UHD-xxx 烧录功能:Load File、Read Master、Program等
  • 禾洛ALL-200工程型万用烧录器 - 半导体芯片烧录-产品型录英文版2025-12-31 17:01
    产品型号:禾洛ALL-200 工程型/量产型 万用IC烧录器/编程器 支援IC种类:支持MCU、Flash、EEPROM、FPGA、CPLD等。 封装覆盖:兼容DIP至BGA、WLCSP等所有主流封装形式。 界面清晰:流程状态同屏实时显示,直观掌控各座状况。 核心架构:16位超频核心,搭载FPGA/CPLD,控制高速精准。 驱动系统:56组精密驱动线路,信号高速、低噪、稳定。
  • 禾洛ALL-200工程型万用烧录器 - 半导体芯片烧录-产品型录中文版2025-12-31 17:00
    产品型号:禾洛ALL-200 工程型/量产型 万用IC烧录器/编程器 支援IC种类:MCU/MPU、NOR/NAND、Flash、CPLD… 支援IC种类:EEPROM、SPI memory、FPGA、etc. 支援封装种类:DIP、SDIP、SOP、SSOP、TSOP、PLCC 支援封装种类:QFP、QFN、SON、BGA、WLCSP、etc. 处理性能:超高时脉设计,大幅缩短大容量芯片烧录时间。
  • 全自动vs手动:哪种芯片烧录机更适合你的工厂产线?2026-01-09 10:39
    本文系统对比了全自动与手动芯片烧录机的核心差异。全自动设备适用于大批量、单一型号的稳定生产,以高投入换取超高产能、极致良率与完整追溯能力。手动设备则凭借极低的切换成本与投入,完美适配小批量、多品种的研发与柔性生产需求。文章指出,选择的关键在于评估未来封装变化频率、订单稳定性、对错误的容忍度及基础设施条件。许多工厂采用“手动上料+自动烧录”的半自动方案作为中间
  • IC测试座定制指南:如何设计高兼容性的芯片测试治具?2026-01-04 13:15
    IC测试座并非简单标准化连接件,其设计优劣直接影响测试信号完整性、效率与成本。高兼容性测试治具设计需立足“系统匹配”:先明确芯片封装、电气等核心约束;再权衡探针、本体、PCB接口板等部件选型;最后通过原型验证、兼容性矩阵管理及持续监控构建闭环。优质设计需平衡多维度需求,适配芯片封装技术演进带来的更高兼容性与智能化要求。
  • 芯片ATE测试详解:揭秘芯片测试机台的工作流程2026-01-04 11:14
    ATE(自动测试设备)是芯片出厂前的关键“守门人”,负责筛选合格品。其工作流程分为测试程序生成载入、参数测量与功能测试(含直流、交流参数及功能测试)、分类分档与数据分析三阶段,形成品质闭环。为平衡效率与精度,并行测试、向量压缩加速、混合信号集成等技术持续演进。ATE融合多领域尖端智慧,是芯片从蓝图到可靠商品的关键支撑,推动电子产业发展。
