--- 产品参数 ---
- 输入电压 2.8V-5V
- 输出电压 固定5V
- 封装 SOT23-6
- 最小包装 3000
--- 产品详情 ---
F Fe ea at tu ur re es s
Fixed 5V Output
VIN Range: 2.8V ~ 5.0V
Output Current: up to 100mA(V IN ≥2.8V)
up to 250mA(V IN ≥3.6V)
Constant Frequency Operation at All Loads
Low Noise Constant Frequency (400kHz)
Operation
Automatic Soft-Start Reduces Inrush
Current
Shutdown Current <1μA
Short-Circuit Protection
No Inductors
Available in Low Profile 6-Lead SOT23
Package
A Ap pp pl li ic ca at ti io on ns s
White LED Backlighting
Li-Ion Battery Backup Supplies
Local 3V to 5V Conversion
Smart Card Readers
D De es sc cr ri ip pt ti io on n
The SC1414 is a low noise, constant frequency
(400kHz) switched capacitor voltage doubler. It
produces a regulated output voltage from a
2.8V to 5.0V input. Low external parts count
(one flying capacitor and two small bypass
capacitors at VIN and VOUT) make the SC1414
ideally suited for small, battery-powered
applications.
The SC1414 have thermal shutdown capability
and can survive a continuous short circuit from
VOUT to GND. Built-in soft-start circuitry
prevents excessive inrush current during
start-up.
High switching frequency enables the use of
small ceramic capacitors. A low current
shutdown feature disconnects the load from VIN
and reduces quiescent current to <1uA.
The SC1414 is available in the SOT-23-6L
power packages.
PCMCIA Local 5V Supplies
为你推荐
输入20V 输出3A大电流3节锂电充电芯片2026-05-26 15:51
产品型号:SC7103 输入耐压:20V 充电电流:3A 封装:SOP8 -
双节锂电充电芯片 3A大电流内置MOS2026-05-26 15:48
产品型号:SC7102 输入耐压:9-20V 充电电流:3A 封装:SOP8 最小包装:3000 -
高压大电流降压芯片2026-05-11 16:05
产品型号:SC910X 输入电压:0-600V 封装:SOP16 -
I14211 40V 600MA 异步降压2026-04-30 09:18
产品型号:I14211 耐压:40V 输出电流:600毫安 封装:SOT23-6 最小包装:4000 -
40V耐压 15A大电流降压芯片2026-04-30 09:13
产品型号:SC2999 输入耐压:40V 封装:SSOP10 最小包装:3000 -
N-MOSFET 200V, 300A, 8.2mΩ TOLL2026-04-28 11:15
产品型号:SC096N20SW10 VDS:200V RDS:8.2mΩ ID:300A 封装:TOLL -
N-MOSFET TOLL 250V, 120A, 15.3mΩ2026-04-28 11:07
产品型号:SC175N25S10 VDS:250V RDS:15.3mΩ ID:120A 封装:TOLL -
无电感升压芯片2026-04-28 09:19
产品型号:SC1414 输入电压:2.8V-5V 输出电压:固定5V 封装:SOT23-6 最小包装:3000 -
升压型大功率 LED 恒流驱动器2026-04-27 12:00
产品型号:SC3688B 输入电压范围:6.5-24V 封装:SOP8 最新包装:3000PCS -
30V耐压 固定输出5V 降压芯片 SOP8封装 2.5A2026-04-27 11:44
产品型号:3989N 输入耐压:30V 输出电压:5V固定 输出电流:2.5A 最小包装:3000PCS
如何选择光继电器和固态继电器和传统机械继电器2026-04-28 10:59
如何选择光继电器和固态继电器和传统机械继电器2026-04-27 11:12
