--- 产品参数 ---
- 最高输入电压 100V
- 封装 SOP8
- 最小包装 3000
--- 产品详情 ---
100V 50mA Very High Voltage Li
SCX2105
near Regulator
General Description
The SCX2105 device is a very high
voltage-tolerant linear regulator that offers the
benefits of a thermally-enhanced package, and is
able to withstand continuous DC or transient input
voltages of up to 100 V. The SCX2105 device is stable
with output capacitance greater than 2.2μF and
any input capacitance greater than 0.47μF.
Therefore, implementations of this device require
minimal board space because of its miniaturized
packaging (PSOP8) and a potentially small output
capacitor. In addition, the SCX2105 device offers
an enable pin (EN) compatible with standard
CMOS logic to enable a low-current shutdown mode
The SCX2105 device has an internal thermal
shutdown and current limiting to protect the
system during fault conditions. The SOP8-EP and
packages have
an operating
temperature range of TJ = –40°C to 125°C. In
addition, the SCX2105 device is ideal for
generating a low-voltage supply from
intermediate voltage rails in telecom and industrial
applications; not only can it supply a well-regulated
voltage rail, but it can also withstand and maintain
regulation during very high and fast voltage
transients. These features translate to simpler
and more cost-effective electrical surge-
protection circuitry for a wide range of
applications, including PoE, bias supply, and LED
lighting.
Ordering Information
Part Number Package Body Size
SOP8-EP
SCX2105
Features
⚫ VIN Range 7 to 100V
⚫ Output Voltage Tolerances of ±1.5%
⚫ Output Current of 50 mA
⚫ Low Quiescent Current 23μA
⚫ Quiescent Current at Shutdown 8μA
⚫ Dropout Voltage 2.8V at I OUT = 50 mA
⚫ Internal Thermal Overload Protection
⚫ Internal Short-Circuit Current Limit
⚫ Adjustable Output Voltage from 1.2 to 90V
Applications
⚫ Microprocessors, Microcontrollers Powered by
Industrial Busses With High Voltage Transients
⚫ Industrial Automation
⚫ Telecom Infrastructure
⚫ Automotive
⚫ Power over Ethernet(PoE)
⚫ LED Lighting
为你推荐
输入20V 输出3A大电流3节锂电充电芯片2026-05-26 15:51
产品型号:SC7103 输入耐压:20V 充电电流:3A 封装:SOP8 -
双节锂电充电芯片 3A大电流内置MOS2026-05-26 15:48
产品型号:SC7102 输入耐压:9-20V 充电电流:3A 封装:SOP8 最小包装:3000 -
高压大电流降压芯片2026-05-11 16:05
产品型号:SC910X 输入电压:0-600V 封装:SOP16 -
I14211 40V 600MA 异步降压2026-04-30 09:18
产品型号:I14211 耐压:40V 输出电流:600毫安 封装:SOT23-6 最小包装:4000 -
40V耐压 15A大电流降压芯片2026-04-30 09:13
产品型号:SC2999 输入耐压:40V 封装:SSOP10 最小包装:3000 -
N-MOSFET 200V, 300A, 8.2mΩ TOLL2026-04-28 11:15
产品型号:SC096N20SW10 VDS:200V RDS:8.2mΩ ID:300A 封装:TOLL -
N-MOSFET TOLL 250V, 120A, 15.3mΩ2026-04-28 11:07
产品型号:SC175N25S10 VDS:250V RDS:15.3mΩ ID:120A 封装:TOLL -
无电感升压芯片2026-04-28 09:19
产品型号:SC1414 输入电压:2.8V-5V 输出电压:固定5V 封装:SOT23-6 最小包装:3000 -
升压型大功率 LED 恒流驱动器2026-04-27 12:00
产品型号:SC3688B 输入电压范围:6.5-24V 封装:SOP8 最新包装:3000PCS -
30V耐压 固定输出5V 降压芯片 SOP8封装 2.5A2026-04-27 11:44
产品型号:3989N 输入耐压:30V 输出电压:5V固定 输出电流:2.5A 最小包装:3000PCS
如何选择光继电器和固态继电器和传统机械继电器2026-04-28 10:59
如何选择光继电器和固态继电器和传统机械继电器2026-04-27 11:12
