--- 产品参数 ---
- 类型 1个N沟道
- 漏源电压(Vdss) 75V
- 连续漏极电流(Id) 130A
- 导通电阻(RDS(o 7.8mΩ@10V,78A
--- 数据手册 ---
--- 产品详情 ---
典型应用
- 工业电机驱动
优势
- 先进的工艺技术
- 超低导通电阻
- 动态电压变化率(dv/dt)额定值
- 175℃工作温度
- 快速开关
- 最高允许结温(Tjmax)内可重复承受雪崩击穿
这款 HEXFET® 功率 MOSFET(金属 - 氧化物半导体场效应晶体管)的条形平面设计,采用了最新的加工技术,以实现每单位硅面积的极低导通电阻。该 HEXFET 功率 MOSFET 的其他特性包括 175℃的结温工作范围、快速的开关速度以及更高的重复雪崩击穿额定值。这些优势结合在一起,使该设计成为一种极为高效可靠的器件,适用于广泛的应用场景。
电气特性(除非另有说明,均在结温\(T_J\) = 25℃ 时测定)
| 参数 | 最小值 | 典型值 | 最大值 | 单位 | 条件 |
\(V_{(BR)DSS}\) | 漏源击穿电压 | 75 | - | V | \(V_{GS}\) = 0V,\(I_D\) = 250μA |
\(\Delta V_{(BR)DSS}/\Delta T\) | 击穿电压温度系数 | 0.09 | - | V/℃ | 参考温度 25℃,\(I_D\) = 1mA |
\(R_{DS(on)}\) | 静态漏源导通电阻 | - | 0.0078 | Ω | \(V_{GS}\) = 10V,\(I_D\) = 78A |
\(V_{GS(th)}\) | 栅极阈值电压 | 2.0 | 4.0 | V | \(V_{DS}\) = 10V,\(I_D\) = 250μA |
\(g_{fs}\) | 正向跨导 | 74 | - | S | \(V_{DS}\) = 25V,\(I_D\) = 78A |
\(I_{DSS}\) | 漏源漏电流 | - | 20 | μA | \(V_{DS}\) = 75V,\(V_{GS}\) = 0V |
| 250 | \(V_{DS}\) = 60V,\(V_{GS}\) = 0V,\(T_J\) = 150℃ | ||||
\(I_{GSS}\) | 栅源正向漏电流 | - | 200 | nA | \(V_{GS}\) = 20V |
| 栅源反向漏电流 | - | 250 | \(V_{GS}\) = -20V | ||
\(Q_{g}\) | 总栅极电荷 | 160 | 200 | nC | \(I_D\) = 78A |
\(Q_{gs}\) | 栅源电荷 | 35 | 52 | \(V_{DS}\) = 60V | |
\(Q_{gd}\) | 栅漏(米勒)电荷 | 54 | 81 | \(V_{DS}\) = 10V | |
\(t_{d(on)}\) | 导通延迟时间 | 11 | - | ns | \(V_{DD}\) = 38V③,\(I_D\) = 78A⑥ |
\(t_r\) | 上升时间 | 150 | - | \(R_D\) = 2.5Ω | |
\(t_{d(off)}\) | 关断延迟时间 | 150 | - | \(V_{GS}\) = 10V③ | |
\(t_f\) | 下降时间 | 140 | - | ||
\(L_D\) | 内部漏感 | - | 4.5 | nH | 带轻载(6mm,0.25in.),从封装到芯片触点,源极接地 |
\(L_S\) | 内部源感 | - | 7.5 | ||
\(C_{iss}\) | 输入电容 | - | 5600 | pF | \(V_{DS}\) = 0V |
\(C_{oss}\) | 输出电容 | - | 890 | \(V_{DS}\) = 25V | |
\(C_{rss}\) | 反向传输电容 | - | 190 | f = 1.0KHz,见图 5 | |
\(C_{oss}\) | 输出电容 | - | 5800 | \(V_{GS}\) = 0V,\(V_{DS}\) = 1.0V,f = 1.0KHz | |
\(C_{oss eff.}\) | 有效输出电容 | 560 | - | \(V_{GS}\) = 0V,\(V_{DS}\) = 60V | |
| 1100 | \(V_{GS}\) = 0V,\(V_{DS}\) = 0V 到 60V |
源漏额定值和特性
\(I_S\) | 连续源极电流 | - | 130⑥ | A | MOSFET 符号表示,含内置反向二极管的整体电流,n 沟道结 |
\(I_{SM}\) | 脉冲源极电流 | - | 520 | ||
\(V_{SD}\) | (体二极管)二极管正向电压 | - | 1.3 | V | \(T_J\) = 25℃,\(I_S\) = 78A,\(V_{GS}\) = 0V④ |
\(t_{rr}\) | 反向恢复时间 | 110 | 170 | ns | \(dI/dt\) = 100A/μs④ |
\(Q_{rr}\) | 反向恢复电荷 | 390 | 590 | nC | |
\(t_{on}\) | 正向导通时间 | - | - | 本征导通时间可忽略(导通主要由\(L_S\) |
更多型号可咨咨询
IRF1404PBF
IRF1405PBF
IRF1407PBF
IRF1404ZPBF
IRF1404ZSTRLPBF
IRF1407STRLPBF
为你推荐
MSS4-Q-T/R——4P3T(四极三掷)、卧式贴片微型滑动开关2026-04-23 16:35
产品型号:MSS4-Q-T/R 触点形式:4P3T (4 极 3 掷、OnOnOn) 额定电流 / 电压:25mA @ 24VDC 接触电阻:≤100mΩ 绝缘电阻:≥100MΩ @ 500VDC -
16TQC10M为10uF ±20% 16V 3528钽电容2026-04-23 16:33
产品型号:16TQC10M 额定电压:16 VDC 静电容量:10 µF 额定纹波电流:800 mA rms ESR(最大):100 mΩ -
BLM15EG121SN1D 是村田0402 封装 (1005)、GHz 频段通用型片式铁氧体磁珠2026-04-23 16:31
产品型号:BLM15EG121SN1D 阻抗 @100MHz:120Ω ±25% 额定电流:1.5A (85℃);0.9A (125℃) 最大直流电阻 (DC:95mΩ 阻抗最小值 @100:100Ω -
SMPI0420T-1R0M一体成型金属粉芯屏蔽型贴片功率电感2026-04-23 16:29
产品型号:SMPI0420T-1R0M 电感值 L:1.0 μH 直流电阻 DCR:25 mΩ 饱和电流 Isat:7.0 A 温升电流 Irms:5.0 A -
HPI0402-1R0M是SMD4*4封装的金属粉芯模压型贴片功率电感2026-04-23 16:27
产品型号:HPI0402-1R0M 电感值 L:1.0 μH 直流电阻 DCR:16.4 mΩ 饱和电流 Isat:9.0 A 温升电流 Irms:6.5 A -
CM8V-T1A 32.768KHZ 12.5PF+/-20PPM-TA-QC2012 封装2012超薄 32.768kHz 音叉石英晶体2026-04-23 16:25
产品型号:CM8V-T1A 32.768KHZ 12.5PF+/-20 标称频率:32.768 kHz 频率精度:±20 ppm 负载电容:12.5 pF 封装尺寸:2.0×1.2×0.35 mm(max) -
MCG30P03-TP是DFN3333 封装的 P 沟道增强型功率 MOSFET2026-04-21 14:28
产品型号:MCG30P03-TP 沟道类型:P 沟道增强型 漏源击穿电压:(V<sub>(BR)DSS</sub>):-30V 连续漏极电流:(I<sub>D</sub>):-19A @ TC=25° 脉冲漏极电流: (I<sub>DM</sub>):-76A 封装形式:DFN3333 (3x3x0.9mm) -
NCV8402ASTT1G/3G是车规级、自保护 N 沟道低压侧智能功率开关2026-04-21 14:25
产品型号:NCV8402ASTT1G/3G 类型:N 沟道、自保护、低压侧(Low-Side)功率开关 耐压:VDS(BR) = 42V(漏源击穿电压) 电流:连续漏电流 ID = 2A(内置限流) 导通电阻:RDS (on) = 165mΩ(最大值,25°C) 封装:SOT-223-4 (TO-261-4),4 引脚表面贴装 -
MAX232DR是封装为SOIC-16的双驱动器/接收器2026-04-21 14:19
产品型号:MAX232DR 类型:双路 RS-232 驱动器 / 接收器 供电:单 5V(4.5–5.5V) 通道:2 驱动器 + 2 接收器 速率:最高 120kbps 温度范围:0°C ~ 70°C -
PIC32MX795F512L-80I/PT TQFP-100 32位闪存微控制器IC2026-04-21 14:15
产品型号: PIC32MX795F512L-80I/PT 主频:80 MHz (105 DMIPS) 工作电压:2.3V ~ 3.6V (典型 3.3V) 温度等级:工业级 -40°C ~ 85°C (后缀 I) Flash 程序存储:512 KB (外加 12 KB 引导 Flash)
