--- 产品详情 ---
| Number of channels (#) | 1 |
| Total supply voltage (Min) (+5V=5, +/-5V=10) | 4.75 |
| Total supply voltage (Max) (+5V=5, +/-5V=10) | 5.25 |
| BW @ Acl (MHz) | 2400 |
| Acl, min spec gain (V/V) | 2 |
| Slew rate (Typ) (V/us) | 3200 |
| Architecture | Fully Differential ADC Driver, Fixed Gain/Buffer, Bipolar |
| Vn at flatband (Typ) (nV/rtHz) | 1.7 |
| Iq per channel (Typ) (mA) | 100 |
| Rail-to-rail | No |
| Vos (offset voltage @ 25 C) (Max) (mV) | 5 |
| Operating temperature range (C) | -40 to 85 |
| Output current (Typ) (mA) | 80 |
| 2nd harmonic (dBc) | 87 |
| 3rd harmonic (dBc) | 103 |
| Frequency of harmonic distortion measurement (MHz) | 10 |
| GBW (Typ) (MHz) | 2400 |
| Input bias current (Max) (pA) | 400000000 |
| Features | Shutdown, On chip gain resistors |
| CMRR (Typ) (dB) | 60 |
| Rating | Catalog |
- 2.4GHz Bandwidth
- 3100V/μs Slew Rate, VOUT =2V Step
- Fixed Voltage Gain: +6dB
- IMD3: –107dBc, VOUT = 2VPP, RL = 400Ω,
f = 100MHz - OIP3: 48dBm, f = 100MHz
- Noise Figure: 11dB, f = 100MHz
The THS770006 is a fixed-gain of +6dB, wideband, fully-differential amplifier designed and optimized specifically for driving 16-bit analog-to-digital converters (ADCs) at input frequencies up to 130MHz, and 14-bit ADCs at input frequencies up to 200MHz. This device provides high bandwidth, high-voltage output with low distortion and low noise, critical in high-speed data acquisition systems that require very high dynamic range, such as wireless base stations and test and measurement applications. This device also makes an excellent differential amplifier for general-purpose, high-speed differential signal chain and short line driver applications.
The THS770006 operates on a nominal +5V single supply, offers very fast, 7.5ns maximum recovery time from overdrive conditions, and has a power-down mode for power saving. The THS770006 is offered in a Pb-free (RoHS compliant) and green, QFN-24 thermally-enhanced package. It is characterized for operation over the industrial temperature range of –40°C to +85°C.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
