--- 产品详情 ---
| Regulated outputs (#) | 3 |
| Vin (Min) (V) | 2.7 |
| Vin (Max) (V) | 5.5 |
| Iout (Max) (A) | 0.9 |
| Rating | Catalog |
| LDO | 2 |
| Iq (Typ) (mA) | 0.07 |
| Processor name | Generic |
| Processor supplier | Generic |
| Shutdown current (ISD) (Typ) (uA) | 2.5 |
| Switching frequency (Typ) (kHz) | 3000 |
| Configurability | Factory programmable |
- DC-DC Regulator
- VOUT_DCDC = 1.2 V to 2.5 V
- 600-mA Maximum ILOAD
- 3-MHz Typical PWM Fixed Switching Frequency
- Automatic PFM/PWM Mode Switching
- Internal Synchronous Rectification
- Internal Soft Start
- Dual-Rail Linear Regulator: LILO
- Load Transients < 50-mV Peak Typical
- Line Transients < 1-mV Peak Typical
- VOUT_LILO = 0.7 V to 2 V
- 70-μA Typical IQ and 300-mA Maximum ILOAD
- Linear Regulator: LDO
- Load Transients < 80-mV Peak Typical
- VOUT_LDO = 1.5 V to 3.3 V
- 50-μA Typical IQ and 350-mA Maximum ILOAD
- Combined Global Features
- VBATT ≥ Maximum (VOUT_LILO + 1.5 V, 2.7 V)
- Operates From a Single Li-Ion Cell or 3-Cell NiMH/NiCd Batteries
- 100-μA IQ and 900-mA Maximum ILOAD
The LM3686 is a step-down DC-DC converter with a very low-dropout linear regulator and a low-noise linear regulator optimized for powering ultra-low voltage circuits. It provides three outputs with combined load current up to 900 mA over an input voltage range from 2.7 V to 5.5 V.
The device offers superior features and performance for many applications. Automatic intelligent switching between PWM low-noise and PFM low-current mode offers improved system control. During full-power operation, a fixed-frequency 3 MHz (typical), PWM mode drives loads from approximately 70 mA to 600 mA maximum. Hysteretic PFM mode extends the battery life through reduction of the quiescent current to 28 μA (typical) at light load and system standby. Internal synchronous rectification provides high efficiency.
For all available packages, see the orderable addendum at the end of the data sheet.All trademarks are the property of their respective owners.
Three enable (EN_x) pins allow the separate operation of either the DC-DC, post-regulation linear regulator, or the linear regulator alone. If the DC-DC is not enabled during start-up of the post-regulation linear regulator, a parallel small-pass transistor supplies the linear regulator from VBATT with maximal 50 mA. In the combined operation where both enables are raised together, the small-pass transistor is deactivated and the big pass transistor provides 350 mA output current. In shutdown mode (EN_x pins pulled low), the device turns off and reduces battery consumption to 2.5 μA (typical).
The LM3686 is available in a 12-pin DSBGA package. A high-switching frequency of 3 MHz (typical) allows the use of a few tiny surface-mount components. Only six external surface-mount components, an inductor and five ceramic capacitors, are required to establish a 15.66 mm2 total solution size.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
