--- 产品详情 ---
| Regulated outputs (#) | 7 |
| Vin (Min) (V) | 2.7 |
| Vin (Max) (V) | 5.5 |
| Iout (Max) (A) | 1.2 |
| Rating | Catalog |
| LDO | 4 |
| Features | Comm Control, Power Sequencing |
| Processor name | OMAP |
| Processor supplier | Texas Instruments |
| Switching frequency (Typ) (kHz) | 3200 |
| Configurability | Factory programmable |
- Three Step-Down Converters:
- Up to 1.2 A of Output Current for VDD1
- TPS65921B Supports VDD1 up to 1.2 A
- TPS65921B1 Supports VDD1 up to 1.4 A (Necessary for 1-GHz Operation)
- SmartReflex Dynamic Voltage Management
- 3.2-MHz Fixed Frequency Operation
- VIN Range from 2.7 to 4.5 V
- Typical 30 μA Quiescent per Converter
- Four General-Purpose Configurable LDOs:
- Dynamic Voltage Scaling
- 220-mA Maximum Current for One LDO
- 2 LDOs With Low Noise and High PSRR
- RTC With Alarm Wake-Up Mechanism
- Clock Management
- 32-kHz Crystal Oscillator
- Clock Slicer for 26, 19.2, and 38.4 MHz
- HF Clock Output Buffer
- USB:
- USB HS 2.0 Transceiver
- USB 1.3 OTG-Compliant
- 12-Bit ULPI 1.1 Interface
- USB Power Supply (5-V CP for VBUS)
- Control
- High-Speed I2C Interface
- All Resource Configurable by I2C
- Keypad Interface up to 8 × 8
- 10-Bit A/D Converter
- Hot-Die, Thermal Shutdown Protection
- μ*BGA 120 Balls ZQZ
The TPS65921 device is a highly integrated power-management circuit (IC) that supports the power and peripheral requirements of the OMAP application processors. The device contains power management, a universal serial bus (USB) high-speed (HS) transceiver, an analog-to-digital converter (ADC), a real-time clock (RTC), a keypad interface, and an embedded power control (EPC). The power portion of the device contains three buck converters, two controllable by a dedicated SmartReflex class-3 interface, multiple low-dropout (LDO) regulators, an EPC to manage the power-sequencing requirements of OMAP, and an RTC module. The USB module provides an HS 2.0 transceiver suitable for direct connection to the OMAP universal transceiver macrocell interface (UTMI) + low pin interface (ULPI) with an integrated charge pump (CP).
The device also provides auxiliary modules: ADC, keypad interface, and general-purpose inputs/outputs (GPIOs) muxed with the JTAG functions. The keypad interface implements a built-in scanning algorithm to decode hardware-based key presses and to reduce software use, with multiple additional GPIOs that can be used as interrupts when they are configured as inputs.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
