--- 产品详情 ---
| Regulated outputs (#) | 14 |
| Vin (Min) (V) | 0.8 |
| Vin (Max) (V) | 5.5 |
| Iout (Max) (A) | 2.5 |
| Rating | Catalog |
| LDO | 10 |
| Iq (Typ) (mA) | 0.008 |
| Features | Comm Control, Dynamic Voltage Scaling, Eco-mode, Over Current Protection, Power Sequencing, Thermal Shutdown, UVLO Fixed |
| Processor name | Generic |
| Processor supplier | Generic |
| Shutdown current (ISD) (Typ) (uA) | 3 |
| Switching frequency (Typ) (kHz) | 2800 |
| Configurability | Factory programmable |
- Four Step-Down Converters:
- VIN Range From 2.7 V to 5.5 V
- Power Save Mode at Light Load Current
- Output Voltage Accuracy in PWM Mode ±2%
- Typical 26-μA Quiescent Current per Converter
- Dynamic Voltage Scaling
- 100% Duty Cycle for Lowest Dropout
- Ten LDOs:
- 8 General-Purpose LDOs
- Output Voltage Range From 0.8 V to 3.3 V
- 2 Low-Noise RF-LDOs
- Output Voltage Range From 1.6 V to 3.3 V
- 32-μA Quiescent Current
- Preregulation Support by Separate Power Inputs
- ECO Mode
- VIN Range of LDOs Respective to the Following Voltage Ranges:
- 1.8 V to 3.6 V
- 3.0 V to 5.5 V
- Three LED Outputs:
- Internal Dimming Using I2C
- Multiplexed With GPIOs
- Up to 20 mA per Current Sink
- Thermal Monitoring
- High Temperature Warning
- Thermal Shutdown
- Bypass Switch
- Used With DCDC4 in Applications Powering an RF-PA
- For Example, as Supply Switch for SD Cards
- Interface
- I2C Interface
- Power I2C Interface for Dynamic Voltage Scaling
- SPI
- 32-kHz RC Oscillator
- Undervoltage Lockout and Battery Fault Comparator
- Long Button-Press Detection
- Flexible Power-Up and Power-Down Sequencing
- 3.6-mm × 3.6-mm DSBGA Package With 0.4-mm Pitch
The TPS65912x device provides four configurable step-down converters with up to 2.5-A output current for memory, processor core, I/O, or preregulation of LDOs. The device also contains ten LDO regulators for external use. These LDOs can be supplied from either a battery or a preregulated supply. Power-up or power-down controller is configurable and can support any power-up or power-down sequences
(OTP-based). The TPS65912x device integrates a 32-kHz RC oscillator to sequence all resources during power up or power down. All LDOs and DC-DC converters can be controlled by I2C-SPI interface or basic ENABLE balls. In addition, an independent automatic voltage-scaling interface allows for transitioning
DC-DC to a different voltage by I2C or basic Roof/Floor Control. Three RGB LEDs with an advanced dimming feature are integrated inside the device. GPIO functionality is multiplexed with LED/ENABLE/SPI when not used. Each GPIO can be configured as part of the power-up sequence to control external resources. One SLEEP pin enables power mode control between active mode and preprogrammed sleep mode for power optimization. For system control, the TPS65912x device has one comparator for system state management. The TPS65912x device comes in a 9-pin × 9-pin DSBGA package (3.6 mm × 3.6 mm) with a 0.4-mm pitch.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
