--- 产品详情 ---
| Output options | Fixed Output |
| Iout (Max) (A) | 0.03 |
| Vin (Max) (V) | 5.2 |
| Vin (Min) (V) | 1.9 |
| Vout (Max) (V) | 1.5 |
| Vout (Min) (V) | 1.5 |
| Fixed output options (V) | 1.5 |
| Noise (uVrms) | 300 |
| Iq (Typ) (mA) | 0.026 |
| Thermal resistance θJA (°C/W) | 171 |
| Rating | Catalog |
| Load capacitance (Min) (μF) | 1 |
| Regulated outputs (#) | 1 |
| Features | Enable |
| Accuracy (%) | 2 |
| PSRR @ 100 KHz (dB) | 23 |
| Dropout voltage (Vdo) (Typ) (mV) | 400 |
| Operating temperature range (C) | -40 to 125 |
- Input Voltage: 1.9 V to 5.2 V
- Operation From a Low Input Voltage: 1.9 V
- Accurate Output Voltage: 1.5 V ± 0.09 V
- Quiescent Current in Shutdown: < 1.5 μA
- Stable With an Output Capacitor: 1 μF
- Ensured Output Current: 30 mA
- Low Output Voltage Noise: 300 μVRMS
- Low Quiescent Current: 29-μA Typical
- Stable With a Ceramic Capacitor
- Logic Controlled Enable
- Fast Turnon and Turnoff
- Thermal-Overload and Short-Circuit Protection
- –40°C to +125°C Junction Temperature Range
The LP3992 regulator is designed to meet the requirements of portable, battery-powered systems providing an accurate output voltage, low noise, and low quiescent current. Battery life is prolonged by the ability of the LP3992 to provide a 1.5-V output from the low input voltage of 1.9 V. Additionally, when switched to a shutdown mode via a logic signal at the enable (EN) pin, the power consumption is reduced to virtually zero. The LP3992 also features short-circuit and thermal-shutdown protection.
The LP3992 is designed to be stable with space-saving ceramic capacitors as small as 1 μF. Performance is specified for a –40°C to +125°C temperature range.
For output voltages other than 1.5 V, and for additional package options, contact TI.
For all available packages, see the orderable addendum at the end of the data sheet.为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
