--- 产品详情 ---
具有使能功能的 100mA、16V、高精度、低压降稳压器
| Output options | Fixed Output |
| Iout (Max) (A) | 0.1 |
| Vin (Max) (V) | 16 |
| Vin (Min) (V) | 2.2 |
| Vout (Max) (V) | 5 |
| Vout (Min) (V) | 2.8 |
| Fixed output options (V) | 2.8, 2.9, 3, 3.3, 5 |
| Noise (uVrms) | 160 |
| Iq (Typ) (mA) | 0.065 |
| Thermal resistance θJA (°C/W) | 205 |
| Rating | Catalog |
| Load capacitance (Min) (μF) | 2.2 |
| Regulated outputs (#) | 1 |
| Features | Enable |
| Accuracy (%) | 2 |
| PSRR @ 100 KHz (dB) | 41 |
| Dropout voltage (Vdo) (Typ) (mV) | 200 |
| Operating temperature range (C) | -40 to 125 |
- Output Tolerance of
- 0.75% (A Grade)
- 1.25% (Standard Grade)
- Ultra-Low Dropout Typically:
- 200 mV at Full Load of 100 mA
- 7 mV at 1 mA
- Low IQ: 600 μA Typical at Full Load of 100 mA
- Shutdown Current: 0.01 μA Typical
- Fast Transient Response to Line and Load
- Overcurrent and Thermal Protection
- High Peak Current Capability
- Low ZOUT Over Wide Frequency Range
- –40°C to 125°C Temperature Range
The LP2981 and LP2981A families of fixed-output, low-dropout regulators offer exceptional, cost-effective performance for both portable and non-portable applications. Available in fixed voltages of 2.8 V, 3 V, 3.3 V, and 5 V, the family has an output tolerance of 0.75% for the A-grade devices (1.25% for the standard grade) and is capable of delivering 100-mA continuous load current. Standard regulator features, such as overcurrent and overtemperature protection, are included.
The LP2981 and LP2981A have features that make the regulators ideal candidates for a variety of portable applications:
- Low dropout: A PNP pass element allows a typical dropout of 200 mV at 100-mA load current and 7 mV at 1-mA load.
- Low quiescent current: The use of a vertical PNP process allows for quiescent currents that are considerably lower than those associated with traditional lateral PNP regulators.
- Shutdown: A shutdown feature is available, allowing the regulator to consume only 0.01 μA when the ON/OFF pin is pulled low.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
