--- 产品详情 ---
Display type | LCD unipolar |
IC integration | Gamma buffer, LCD bias, LCD level shifter, VCOM |
Vin (Min) (V) | 8.6 |
Vin (Max) (V) | 15.5 |
Source driver voltage (Min) (V) | 12.7 |
Source driver voltage (Max) (V) | 19 |
Level shifter/scan driver (ch) | 12 |
V_POS (Min) (V) | 19 |
V_POS (Max) (V) | 34 |
V_NEG (Min) (V) | -8.1 |
V_NEG (Max) (V) | -1.8 |
Features | GPM or GVS, Gamma buffer, HAVDD, I2C interface, Level shifter, Reset generator, Temperature sensor or compensation, VCOM or op amp |
Topology | Boost, Buck |
Rating | Catalog |
- 8.6V to 14.7V Input Voltage Range
- Boost Converter VDD: 12.7V…19V (6-Bit)
- Integrated Input-to-Output Isolation Switch
- Buck Converter HVDD: VDD Tracking
- Buck Converter VCC: 1.6V...2.0V & 3.0V…3.6V (4-Bit)
- Positive Charge Pump VGH:
- 19V…34V for Low Temperature (4-Bit)
- 17V…32V for High Temperature (4-Bit)
- Negative Charge Pump VGL: –1.8V…–8.1V (6-Bit)
- 6-Ch Gamma Buffer:
- 3-Ch: VDD…HVDD (9-Bit)
- 3-Ch: HVDD...GND (9-Bit)
- 9-Bit VCOM Reference
- 3-Bit VCOM Gain
- VCOM_DAC Output for External Operational Amplifier Reference
- Temperature Compensation for VGH and VCOM
- Reset Signal with Programmable Delay Time
- Programmable Sequencing Delays (4 × 3-Bit)
- Thermal Shutdown
- 12-Channel Level Shifters:
- Supports Forward and Reverse Operation
- Abnormal Operation Detection
- 56-Pin 7-mm × 7-mm QFN Package
The TPS65175B/C provides a simple and economic power supply solution for a wide variety of LCD bias applications. The device provides all supply rails needed by a TFT-LCD panel but also 6 gamma references, a supply rail for LVDS support, as well as a Vcom reference. The device also integrates a VCOM_DAC rail providing the reference for an external non-inverting operational amplifier input. A 12-Channel Level Shifter is also integrated. The solution is delivered in a small 7×7 mm QFN package.
The TPS65175B/C provides a simple and economic power supply solution for a wide variety of LCD bias applications. The device provides all supply rails needed by a TFT-LCD panel. VCC and RST for the T-Con. VDD and HVDD for the Source Driver. VGH and VGL for the Gate Driver or the Level Shifters. A VCOM operational amplifier is also integrated to provide a common plane reference. The VGH and VCOM / VCOM_DAC voltages can be compensated for low and high temperatures. The transition from one programmed value to another is made using an external thermistor connected to the IC. In addition, a 6-channel Gamma Buffer as well as a 12-Channel Level Shifter are integrated. All output rails and delay times are programmable by a two-wire interface: a single BOM (Bill of Material) can cover several panel types and sizes whose desired output levels can be programmed in production and stored in a non-volatile memory embedded into the TPS65175B/C. The solution is delivered in a small 7 mm × 7 mm QFN-56 package.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
