--- 产品详情 ---
| DSP | 1 C2x |
| DSP MHz (Max) | 50 |
| CPU | 32-bit |
| Rating | Military |
| Operating temperature range (C) | -55 to 125 |
- Single-Chip Parallel Multiple Instruction/Multiple Data (MIMD) Digital Signal Processor (DSP)
- More Than Two Billion RISC-Equivalent Operations per Second
- Master Processor (MP)
- 32-Bit Reduced Instruction Set Computing (RISC) Processor
- IEEE-754 Floating-Point Capability
- 4K-Byte Instruction Cache
- 4K-Byte Data Cache
- Four Parallel Processors (PP)
- 32-Bit Advanced DSPs
- 64-Bit Opcode Provides Many Parallel Operations per Cycle
- 2K-Byte Instruction Cache and 8K-Byte Data RAM per PP
- Transfer Controller (TC)
- 64-Bit Data Transfers
- Up to 400 Megabytes per Second (MBps) Transfer Rate
- 32-Bit Addressing
- Direct DRAM/VRAM Interface With Dynamic Bus Sizing
- Intelligent Queuing and Cycle Prioritization
- Video Controller (VC)
- Provides Video Timing and Video Random-Access Memory (VRAM) Control
- Dual-Frame Timers for Two Simultaneous Image-Capture and/or Display Systems
- Big- or Little-Endian Operation
- 50K-Byte On-Chip RAM
- 4G-Byte Address Space
- 20-ns Cycle Time
- 3.3-V Operation
- IEEE Standard 1149.1
Test Access Port (JTAG) - Operating Temperature Range
–55°C to 125°C - M-Temperature
–40°C to 85°C - A-Temperature
IEEE Standard 1149.1–1990, IEEE Standard Test Access Port and Boundary-Scan Architecture
The SMJ320C80 is a single-chip, MIMD parallel processor capable of performing over two billion operations per second. It consists of a 32-bit RISC master processor with a 100-MFLOPS (million floating-point operations per second) IEEE floating-point unit, four 32-bit parallel processing digital signal processors (DSPs), a transfer controller with up to 400-MBps off-chip transfer rate, and a video controller. All the processors are coupled tightly through an on-chip crossbar that provides shared access to on-chip RAM. This performance and programmability make the ?C80 ideally suited for video, imaging, and high-speed telecommunications applications.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
