--- 产品详情 ---
具有 I2C 接口的 8 位、8 通道采样模数转换器
| Resolution (Bits) | 8 |
| Number of input channels | 8 |
| Sample rate (Max) (kSPS) | 70 |
| Interface type | I2C |
| Architecture | SAR |
| Input type | Pseudo-Differential, Single-Ended |
| Multi-channel configuration | Multiplexed |
| Rating | Catalog |
| Reference mode | Ext, Int |
| Input range (Max) (V) | 5.25 |
| Input range (Min) (V) | 0 |
| Operating temperature range (C) | -40 to 85 |
| Power consumption (Typ) (mW) | 0.75 |
| Analog voltage AVDD (Min) (V) | 2.7 |
| SNR (dB) | 50 |
| Analog voltage AVDD (Max) (V) | 5.25 |
| INL (Max) (+/-LSB) | 0.5 |
| Digital supply (Min) (V) | 2.7 |
| Digital supply (Max) (V) | 5.25 |
- 70kHz SAMPLING RATE
- ±0.5LSB INL/DNL
- 8 BITS NO MISSING CODES
- 4 DIFFERENTIAL/8 SINGLE-ENDED INPUTS
- 2.7V TO 5V OPERATION
- BUILT-IN 2.5V REFERENCE/BUFFER
- SUPPORTS ALL THREE I2C MODES:
Standard, Fast, and High-Speed - LOW POWER:
180μW (Standard Mode)
300μW (Fast Mode)
675μW (High-Speed Mode) - DIRECT PIN COMPATIBLE WITH ADS7828
- TSSOP-16 PACKAGE
The ADS7830 is a single-supply, low-power, 8-bit data acquisition device that features a serial I2C interface and an 8-channel multiplexer. The Analog-to-Digital (A/D) converter features a sample-and-hold amplifier and internal, asynchronous clock. The combination of an I2C serial, 2-wire interface and micropower consumption makes the ADS7830 ideal for applications requiring the A/D converter to be close to the input source in remote locations and for applications requiring isolation. The ADS7830 is available in a TSSOP-16 package.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
