--- 产品详情 ---
| Sample rate (Max) (MSPS) | 1000 |
| Resolution (Bits) | 12 |
| Number of input channels | 1 |
| Interface type | Parallel LVDS |
| Analog input BW (MHz) | 2150 |
| Features | Ultra High Speed |
| Rating | Space |
| Input range (Vp-p) | 2 |
| Power consumption (Typ) (mW) | 2200 |
| Architecture | Pipeline |
| SNR (dB) | 58.5 |
| ENOB (Bits) | 9.55 |
| SFDR (dB) | 77.9 |
| Operating temperature range (C) | -55 to 125, 25 to 25 |
| Input buffer | Yes |
- 1-GSPS sample rate
- 12-Bit resolution
- 2.1 GHz input bandwidth
- SFDR = 65 dBc at 1.2 GHz
- SNR = 57 dBFS at 1.2 GHZ
- 7 Clock cycle latency
- Interleave friendly: internal adjustments for gain, phase and offset
- 1.5 - 2 VPP Differential input voltage, programmable
- LVDS-compatible outputs, 1 or 2 bus options
- Total power dissipation: 2.2 W
- On-chip analog buffer
- 100-pin ceramic nonconductive tie-bar package
- Military temperature range
(–55°C to 125°C Tcase) - Processed per internal QML class V assembly/test flow
- QML class V qualified, SMD 5962-09240
The ADS5400 is a 12-bit, 1-GSPS analog-to-digital converter (ADC) that operates from both a 5-V supply and 3.3-V supply, while providing LVDS-compatible digital outputs. The analog input buffer isolates the internal switching of the track and hold from disturbing the signal source. The simple 3-stage pipeline provides extremely low latency for time critical applications. Designed for the conversion of signals up to 2 GHz of input frequency at 1 GSPS, the ADS5400 has outstanding low noise performance and spurious-free dynamic range over a large input frequency range.
The ADS5400 is available in a 100-Pin Ceramic Nonconductive Tie-Bar Package. The combination of the ceramic package and moderate power consumption of the ADS5400 allows for operation without an external heatsink. The ADS5400 is built on Texas Instrument?s complementary bipolar process (BiCom3) and is specified over the full military temperature range (–55°C to 125°C Tcase).
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
