--- 产品详情 ---
具有 2Vrms 驱动器的 4 通道/4 通道音频编解码器
| Number of ADC channels | 2 |
| Number of DAC channels (#) | 2 |
| Digital audio interface | I2S, LJ, RJ |
| Analog inputs | 12 |
| Sampling rate (Max) (kHz) | 192 |
| Rating | Catalog |
| Features | Stereo headphone amplifier |
| ADC SNR (Typ) (dB) | 95 |
| DAC SNR (Typ) (dB) | 100 |
- 2- or 2.4-VRMS Output (Typ), 2-VRMS Input (Typ)
- Asynchronous Operation for 2 Stereo DACs and 2 Stereo ADCs
- 6 Audio Interface Ports with Mux and Bypass
- Performance:
- THD+N (fS = 48 kHz): 0.01% (ADC), 0.01% (DAC)
- SNR/DR (fS = 48 kHz): 95 dB (ADC), 100 dB (DAC)
- Line Input (Stereo x6): Available for 2-VRMS Input
- Line Output (Stereo x2): Available for 2-VRMS or 2.4-VRMS Output
- Headphone Output: > 20 mW into 32
, > 30 mW into 16
- Sampling Rate: 96 kHz (ADC), 192 kHz (DAC)
- System Clock: 128 fS, 192 fS, 256 fS, 384 fS, 512 fS, 768 fS
- Digital Filter Passband Ripple: ±0.05 dB (ADC), ±0.04 dB (DAC)
- Digital Filter Stop Band Attenuation: –65 dB (ADC), –50 dB (DAC)
- I2C Interface
- Multifunctions:
- Audio Interface:
I2S, Left-Justified, and Right-Justified - Digital Attenuation: 0 dB to –100 dB in 0.5-dB Steps (DAC), 20 dB to –100 dB in 0.5-dB Steps (ADC)
- Digital Soft Mute: 1.0-dB Steps to Mute
- Digital De-Emphasis Filter: 32, 44.1, 48 kHz
- Digital Audio Interface Mux and Bypass
- Line Input Level Control: 9, 6, 3, 0 dB
- Line Output Level Control: 0, –0.5, –1.0 dB
- Headphone Output Volume Control:
12 dB to –70 dB in 1-dB Steps - Oversampling Rate Control for DAC
- Audio Interface:
- Power-Supply Voltage:
- 9 V for 2-VRMS Driver
- 3.3 V for Digital and Analog
- Power Consumption:
- 360 mW at fS = 48-kHz Operation
- 25.5 μW in Power-Down Mode
- Pop Noise Reduction at Clock Halt
- Short-Circuit Protection for Headphone Output
- Flexible GPIO Port:
- Internal Mute Flag
- Internal Zero Flag
- Headphone Insertion Detection Status
- Headphone Short-Circuit Protection Status
- Logic Functions (AND, NAND, OR, NOR, BUF, INV)
- Package: 64-Pin HTQFP PowerPAD
- Operating Temperature Range:–25°C to +85°C
- APPLICATIONS
- Digital TV
- DVD Recorder
- IP-STB (Set Top Box)
The PCM5310 is a four-channel/four-channel audio codec with a 2-VRMS driver, headphone amplifier, analog multiplexer (mux), and six audio interface ports for digital TV applications.
The PCM5310 accepts left-justified, right-justified, and I2S audio data formats with 16 or 24 bits. The PCM5310 also incorporates many functions through the I2C interface, such as an analog bypass mode, analog volume control, analog level control, analog multiplexer, GPIO, zero flag, short protection, de-emphasis filter, high-pass filter, and digital attenuator. The six audio interface ports each have a built-in digital mux and bypass functions to reduce the need for additional DSP ports or other devices.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
