--- 产品详情 ---
| Available channels | 4 |
| Operating temperature range (C) | -40 to 85 |
| Output current (Typ) (mA) | 600 |
| Rating | Catalog |
- Fast Switching: Rise and Fall Times: 0.6/1.0 ns.
- Low Voltage Differential Signaling (LVDS) Channels Enable Interface for the Fast Switching Lines
- Low Output Current Noise: 0.24 nA/√Hz
- Dual Output: Selectable by SELA/B Pin (Active HIGH)
- SELA = LMH6526?SEB = LMH6525
- Four Independent Current Channels
- Gain of 300, 300 mA Write Channel
- Gain of 150, 150 mA Low-Noise Read Channel
- Two Gain of 150, 150 mA Write Channels
- 600 mA Minimum Combined Output Current
- Integrated AC Coupled HFM Oscillator
- Selectable Frequency and Amplitude Setting
- By External Resistors
- 200 MHz to 600 MHz Frequency Range
- Amplitude to 100 mA Peak-to-Peak Modulation
- Complete Shutdown by ENABLE Pin
- 5V Single-Supply Operation
- Logic inputs TTL and CMOS compatible
- Space Saving Package (OFN)
- LMH6525 has Differential Enable Oscillator Inputs
- LMH6526 has Single Ended Enable Oscillator Inputs
All trademarks are the property of their respective owners.
The LMH6525/6526 is a laser diode driver for use in combination DVD/CD recordable and rewritable systems. The part contains two high-current outputs for reading and writing the DVD (650 nm) and CD (780 nm) lasers. Functionality includes read, write and erase through four separate switched current channels. The channel currents are summed together at the selected output to generate multilevel waveforms for reading, writing and erasing of optical discs. The LVDS interface delivers DVD write speeds of 16x and higher while minimizing noise and crosstalk. The LMH6525/6526 is optimized for both speed and power consumption to meet the demands of next generation systems. The part features a 150 mA read channel plus one 300 mA and two 150 mA write channels, which can be summed to allow a total output current of 600 mA or greater. The channel currents are set through four independent current inputs.
An on-board High-Frequency Modulator (HFM) oscillator helps reduce low-frequency noise of the laser and is enabled by applying LVDS levels on the ENOSC pins for the LMH6525, while the LMH6526 is enabled by applying an asymmetrical signal on the ENOSC pin. The fully differential oscillator circuit minimizes supply line noise, easing FCC approval of the overall system. The SELA/B pin (active HIGH) selects the output channel and oscillator settings. External resistors determine oscillator frequency and amplitude for each setting. The write and erase channels can be switched on and off through dedicated LVDS interface pins.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
