--- 产品详情 ---
| Architecture | FET / CMOS Input, Voltage FB |
| Number of channels (#) | 1 |
| Total supply voltage (Min) (+5V=5, +/-5V=10) | 10 |
| Total supply voltage (Max) (+5V=5, +/-5V=10) | 32 |
| GBW (Typ) (MHz) | 210 |
| BW @ Acl (MHz) | 325 |
| Acl, min spec gain (V/V) | 1 |
| Slew rate (Typ) (V/us) | 1000 |
| Vn at flatband (Typ) (nV/rtHz) | 7 |
| Vn at 1 kHz (Typ) (nV/rtHz) | 7 |
| Iq per channel (Typ) (mA) | 11.5 |
| Vos (offset voltage @ 25 C) (Max) (mV) | 0.5 |
| Rail-to-rail | No |
| Rating | Catalog |
| Operating temperature range (C) | -40 to 85 |
| CMRR (Typ) (dB) | 95 |
| Input bias current (Max) (pA) | 100 |
| Offset drift (Typ) (uV/C) | 2.5 |
| Output current (Typ) (mA) | 95 |
| 2nd harmonic (dBc) | 76 |
| 3rd harmonic (dBc) | 94 |
| Frequency of harmonic distortion measurement (MHz) | 5 |
- High Bandwidth:
- 325 MHz in Unity Gain
- 210 MHz Gain Bandwidth Product
- High Slew Rate:
- 900 V/μs (G = 2)
- 1000 V/μs (G = 5)
- Low Distortion of –76 dB, SFDR at 5 MHz
- Maximum Input Bias Current: 100 pA
- Input Voltage Noise: 7 nV/√Hz
- Maximum Input Offset Voltage: 500 μV at 25°C
- Low Offset Drift: 2.5 μV/°C
- Input Impedance: 109 || 3.9 pF
- Wide Supply Range: ± 5 V to ± 15 V
- High Output Current: 95 mA
The THS4631 is a high-speed, FET-input operational amplifier designed for applications requiring wideband operation, high-input impedance, and high-power supply voltages. By providing a 210-MHz gain bandwidth product, ±15-V supply operation, and 100-pA input bias current, the THS4631 is capable of simultaneous wideband transimpedance gain and large output signal swing. The fast 1000 V/μs slew rate allows for fast settling times and good harmonic distortion at high frequencies. Low current and voltage noise allow amplification of extremely low-level input signals while still maintaining a large signal-to-noise ratio.
The characteristics of the THS4631 make it ideally suited for use as a wideband photodiode amplifier. Photodiode output current is a prime candidate for transimpedance amplification as shown below. Other potential applications include test and measurement systems requiring high-input impedance, ADC and DAC buffering, high-speed integration, and active filtering.
The THS4631 is offered in an 8-pin SOIC (D), and the 8-pin SOIC (DDA) and MSOP (DGN) with PowerPAD? package.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
