--- 产品详情 ---
| Architecture | Current FB |
| Number of channels (#) | 1 |
| Total supply voltage (Min) (+5V=5, +/-5V=10) | 10 |
| Total supply voltage (Max) (+5V=5, +/-5V=10) | 12 |
| GBW (Typ) (MHz) | 1700 |
| BW @ Acl (MHz) | 1700 |
| Acl, min spec gain (V/V) | 1 |
| Slew rate (Typ) (V/us) | 3100 |
| Vn at flatband (Typ) (nV/rtHz) | 1.83 |
| Vn at 1 kHz (Typ) (nV/rtHz) | 4.5 |
| Iq per channel (Typ) (mA) | 12.5 |
| Vos (offset voltage @ 25 C) (Max) (mV) | 4.5 |
| Rail-to-rail | No |
| Rating | Space |
| Operating temperature range (C) | -55 to 125 |
| CMRR (Typ) (dB) | 48 |
| Input bias current (Max) (pA) | 15000000 |
| Offset drift (Typ) (uV/C) | 13 |
| Output current (Typ) (mA) | 80 |
| 2nd harmonic (dBc) | 52 |
| 3rd harmonic (dBc) | 62 |
| Frequency of harmonic distortion measurement (MHz) | 20 |
- VS = ±5V, TA = 25°C, AV = +2V/V, RL = 100?, VOUT = 2VPP, Typical Unless Noted:
- Available with Radiation Ensurance
- High Dose Rate 300 krad(Si)
- ELDRS Free 300 krad(Si)
- ?3dB Bandwidth (VOUT = 0.2 VPP) 720 MHz
- Low Noise 1.83nV/√Hz
- Fast Settling to 0.1% 13.4ns
- Fast Slew Rate 3100V/μs
- Supply Current 12.5mA
- Output Current 80mA
- Low Intermodulation Distortion (75MHz) ?67dBc
- Improved Replacement for CLC409 and CLC449
All trademarks are the property of their respective owners.
The LMH6702 is a very wideband, DC coupled monolithic operational amplifier designed specifically for wide dynamic range systems requiring exceptional signal fidelity. Benefitting from TI's current feedback architecture, the LMH6702 offers unity gain stability at exceptional speed without need for external compensation.
With its 720MHz bandwidth (AV = 2V/V, VO = 2VPP), 10-bit distortion levels through 60MHz (RL = 100?), 1.83nV/√Hz input referred noise and 12.5mA supply current, the LMH6702 is the ideal driver or buffer for high-speed flash A/D and D/A converters.
Wide dynamic range systems such as radar and communication receivers, requiring a wideband amplifier offering exceptional signal purity, will find the LMH6702's low input referred noise and low harmonic and intermodulation distortion make it an attractive high speed solution.
The LMH6702 is constructed using TI's VIP10 complimentary bipolar process and TI's proven current feedback architecture.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
