--- 产品详情 ---
| Architecture | FET / CMOS Input, Voltage FB |
| Number of channels (#) | 1 |
| Total supply voltage (Min) (+5V=5, +/-5V=10) | 1.8 |
| Total supply voltage (Max) (+5V=5, +/-5V=10) | 5.5 |
| GBW (Typ) (MHz) | 88 |
| BW @ Acl (MHz) | 8.8 |
| Acl, min spec gain (V/V) | 10 |
| Slew rate (Typ) (V/us) | 28 |
| Vn at flatband (Typ) (nV/rtHz) | 5.8 |
| Vn at 1 kHz (Typ) (nV/rtHz) | 5.8 |
| Iq per channel (Typ) (mA) | 1.15 |
| Vos (offset voltage @ 25 C) (Max) (mV) | 0.15 |
| Rail-to-rail | In to V-, Out |
| Features | Decompensated |
| Rating | Catalog |
| Operating temperature range (C) | -40 to 125 |
| CMRR (Typ) (dB) | 100 |
| Input bias current (Max) (pA) | 1 |
| Offset drift (Typ) (uV/C) | 1 |
| Output current (Typ) (mA) | 21 |
- (Typical 5V Supply, Unless Otherwise Noted)
- Renewable Energy Grade
- Input Offset Voltage ±150 μV (max)
- Input Referred Voltage Noise 5.8 nV/√Hz
- Input Bias Current 100 fA
- Gain Bandwidth Product 88 MHz
- Supply Voltage Range 1.8V to 5.5V
- Supply Current 1.15mA
- Rail-to-Rail Output Swing
- @ 10 k? Load 25 mV from Rail
- @ 2 k? Load 45 mV from Rail
- 2.5V and 5.0V Performance
- Total Harmonic Distortion 0.04% @1 kHz, 600?
- Temperature Range ?40°C to 125°C
All trademarks are the property of their respective owners.
The SM73302 low noise, CMOS input operational amplifier offers a low input voltage noise density of 5.8 nV/√Hz while consuming only 1.15 mA of quiescent current. The SM73302 is stable at a gain of 10 and has a gain bandwidth (GBW) product of 88 MHz. The SM73302 has a supply voltage range of 1.8V to 5.5V and can operate from a single supply. The SM73302 features a rail-to-rail output stage, and is part of the precision amplifier family and is ideal for a variety of instrumentation applications.
The SM73302 provides optimal performance in low voltage and low noise systems. A CMOS input stage, with typical input bias currents in the range of a few femtoamperes, and an input common mode voltage range, which includes ground, makes the SM73302 ideal for low power sensor applications where high speeds are needed.
The SM73302 is manufactured using an advanced VIP50 process. The SM73302 is offered in a 5-Pin SOT-23 package.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
