--- 产品详情 ---
| Architecture | Voltage FB |
| Number of channels (#) | 2 |
| Total supply voltage (Min) (+5V=5, +/-5V=10) | 2.7 |
| Total supply voltage (Max) (+5V=5, +/-5V=10) | 11 |
| GBW (Typ) (MHz) | 63 |
| BW @ Acl (MHz) | 140 |
| Acl, min spec gain (V/V) | 1 |
| Slew rate (Typ) (V/us) | 57 |
| Vn at flatband (Typ) (nV/rtHz) | 10 |
| Vn at 1 kHz (Typ) (nV/rtHz) | 10 |
| Iq per channel (Typ) (mA) | 1.45 |
| Vos (offset voltage @ 25 C) (Max) (mV) | 0.75 |
| Rail-to-rail | In, Out |
| Rating | Automotive |
| Operating temperature range (C) | -40 to 105 |
| CMRR (Typ) (dB) | 108 |
| Input bias current (Max) (pA) | 2400000 |
| Offset drift (Typ) (uV/C) | 0.9 |
| Output current (Typ) (mA) | 35 |
| 2nd harmonic (dBc) | 75 |
| 3rd harmonic (dBc) | 75 |
| Frequency of harmonic distortion measurement (MHz) | 1 |
- VS = 5V, RL = 1 kΩ, TA = 25°C and AV = +1,
unless otherwise specified. - Operating voltage range 2.7V to 11V
- Supply current per channel 1.25 mA
- Small signal bandwidth 130 MHz
- Input offset voltage (limit at 25°C) ±0.75 mV
- Slew rate 55 V/μs
- Settling time to 0.1% 90 ns
- Settling time to 0.01% 120 ns
- SFDR (f = 100 kHz, AV = +1, VOUT = 2 VPP) 100 dBc
- 0.1 dB bandwidth (AV = +2) 15 MHz
- Low voltage noise 10 nV/√Hz
- Rail-to-Rail input and output
- AEC-Q100 grade 2 qualified –40°C to +105°C
- Manufactured on an automotive grade flow
The LMH6619Q (dual) is a 130 MHz rail-to-rail input and output amplifier designed for ease of use in a wide range of applications requiring high speed, low supply current, low noise, and the ability to drive complex ADC and video loads. The operating voltage range extends from 2.7V to 11V and the supply current is typically 1.25 mA per channel at 5V. The LMH6619Q is a member of the PowerWise? family and have an exceptional power-to- performance ratio.
The amplifier?s voltage feedback design topology provides balanced inputs and high open loop gain for ease of use and accuracy in applications such as active filter design. Offset voltage is typically 0.1 mV and settling time to 0.01% is 120 ns which combined with an 100 dBc SFDR at 100 kHz makes the part suitable for use as an input buffer for popular 8-bit, 10-bit, 12-bit and 14-bit mega-sample ADCs.
The input common mode range extends 200 mV beyond the supply rails. On a single 5V supply with a ground terminated 150Ω load the output swings to within 37 mV of the ground rail, while a mid-rail terminated 1 kΩ load will swing to 77 mV of either rail, providing true single supply operation and maximum signal dynamic range on low power rails. The amplifier output will source and sink 35 mA and drive up to 30 pF loads without the need for external compensation.
The LMH6619Q is offered in the 8-Pin SOIC package.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
