--- 产品详情 ---
Quad, 40-V, 5.25-MHz, 4-mV offset voltage, 20-V/μs, In to V+ op amp with -40°C to 125°C operation
| Number of channels (#) | 4 |
| Total supply voltage (Max) (+5V=5, +/-5V=10) | 40 |
| Total supply voltage (Min) (+5V=5, +/-5V=10) | 4.5 |
| Rail-to-rail | In to V+ |
| GBW (Typ) (MHz) | 5.25 |
| Slew rate (Typ) (V/us) | 20 |
| Vos (offset voltage @ 25 C) (Max) (mV) | 4 |
| Iq per channel (Typ) (mA) | 0.9375 |
| Vn at 1 kHz (Typ) (nV/rtHz) | 37 |
| Rating | Catalog |
| Operating temperature range (C) | -40 to 125 |
| Offset drift (Typ) (uV/C) | 2 |
| Features | Cost Optimized, EMI Hardened, Small Size, Standard Amps |
| Input bias current (Max) (pA) | 120 |
| CMRR (Typ) (dB) | 105 |
| Output current (Typ) (mA) | 26 |
| Architecture | CMOS |
- High slew rate: 20 V/μs (TL08xH, typ)
- Low offset voltage: 1 mV (TL08xH, typ)
- Low offset voltage drift: 2 μV/°C
- Low power consumption: 940 μA/ch (TL08xH, typ)
- Wide common-mode and differential voltage ranges
- Common-mode input voltage range includes VCC+
- Low input bias and offset currents
- Low noise: Vn = 18 nV/√Hz (typ) at f = 1 kHz
- Output short-circuit protection
- Low total harmonic distortion: 0.003% (typ)
- Wide supply voltage: ±2.25 V to ±20 V, 4.5 V to 40 V
The TL08xH (TL081H, TL082H, and TL084H) family of devices are the next-generation versions of the industry-standard TL08x (TL081, TL082, and TL084) devices. These devices provide outstanding value for cost-sensitive applications, with features including low offset (1 mV, typical), high slew rate (20 V/μs), and common-mode input to the positive supply. High ESD (1.5 kV, HBM), integrated EMI and RF filters, and operation across the full –40°C to 125°C enable the TL08xH devices to be used in the most rugged and demanding applications.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
