--- 产品详情 ---
| Number of channels (#) | 2 |
| Total supply voltage (Max) (+5V=5, +/-5V=10) | 36 |
| Total supply voltage (Min) (+5V=5, +/-5V=10) | 8 |
| Vos (offset voltage @ 25 C) (Max) (mV) | 0.3 |
| GBW (Typ) (MHz) | 45 |
| Features | MUX Friendly |
| Slew rate (Typ) (V/us) | 150 |
| Rail-to-rail | Out |
| Offset drift (Typ) (uV/C) | 0.3 |
| Iq per channel (Typ) (mA) | 5.5 |
| Vn at 1 kHz (Typ) (nV/rtHz) | 4 |
| CMRR (Typ) (dB) | 115 |
| Rating | Catalog |
| Operating temperature range (C) | -40 to 125 |
| Input bias current (Max) (pA) | 8 |
| Output current (Typ) (mA) | 30 |
| Architecture | FET |
| THD + N @ 1 kHz (Typ) (%) | 0.0000316 |
- Low input voltage noise density: 4 nV/√Hz at 1 kHz
- Input voltage noise: 0.1 Hz to 10 Hz: 60 nVRMS
- Low input bias current: 1 pA
- Input offset voltage: 50 μV
- Input offset drift: 0.45 μV/°C
- MUX-friendly inputs
- Gain bandwidth: 45 MHz
- Slew rate: 150 V/μs
- 14-bit settling time: 120 ns
- Overload power limiter
- Wide supply voltage range: ±4 V to ±18 V
- Packages:
- 8-pin SOIC
- 8-pin HVSSOP (preview)
The OPA828 and OPA2828 ( OPAx828) JFET input operational amplifiers are the next generation OPA627 and OPA827, combining high speed with high dc precision and ac performance. These op amps supply low offset voltage (50 μV), low drift over temperature (0.45 μV/°C, typical), low bias current (1 pA, typical), and low noise (4 nV/√Hz, typical) with only 60-nVRMS 0.1-Hz to 10-Hz noise. The OPAx828 operate over a wide supply-voltage range of ±4 V to ±18 V and a supply current of 5.5 mA/channel, typical.
AC characteristics, including a 45-MHz gain bandwidth product (GBW), a slew rate of 150?V/μs, and precision dc characteristics, make the OPAx828 excellent choices for a variety of systems. These include high-speed and high-resolution data-acquisition systems, such as 16-bit to 18-bit mixed signal systems, transimpedance (I/V-conversion) amplifiers, filters, precision ±10-V front ends, and high-impedance sensor-interface applications.
The OPAx828 are available in an 8-pin SOIC package and a thermally enhanced, 8-pin HVSSOP PowerPAD? integrated circuit package.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
