--- 产品详情 ---
AEC-Q100、2.7V 至 36V、440kHz 可变增益电流感应放大器
| Common mode voltage (Max) (V) | 36 |
| Common mode voltage (Min) (V) | 2.7 |
| Input offset (+/-) (Max) (uV) | 2000 |
| Input offset drift (+/-) (Typ) (uV/C) | 1 |
| Gain (V/V) | Adjustable |
| Gain error (%) | 2 |
| Gain error drift (+/-) (Max) (ppm/°C) | 100 |
| CMRR (Min) (dB) | 100 |
| Bandwidth (kHz) | 440 |
| Supply voltage (Max) (V) | 40 |
| Supply voltage (Min) (V) | 2.7 |
| Iq (Max) (mA) | 0.125 |
| Number of channels (#) | 1 |
| Comparators (#) | 0 |
| Features | Current Output |
| Rating | Automotive |
| Operating temperature range (C) | -40 to 125 |
- Qualified for Automotive Applications
- AEC-Q100 Qualified With the Following Results:
- Device Temperature Grade 1: ?40°C to 125°C
Ambient Operating Temperature Range - Device HBM ESD Classification Level 2
- Device CDM ESD Classification Level C6
- Complete Unidirectional High-Side Current Measurement Circuit
- Wide Supply and Common-Mode Ranges
- INA139-Q1: 2.7 V to 40 V
- INA169-Q1: 2.7 V to 60 V
- Independent Supply and Input Common-Mode
Voltages - Single Resistor Gain Set
- Low Quiescent Current (60 μA Typical)
- Wide Temperature Range: –40°C to +125°C
- Package: TSSOP-8
The INA139-Q1 and INA169-Q1 (INA1x9-Q1) are high-side, unidirectional, current shunt monitors. Wide input common-mode voltage range, high-speed, low quiescent current, and TSSOP-8 packaging enable use in a variety of applications.
The device converts a differential input voltage to a current output. This current is converted back to a voltage with an external load resistor that sets any gain from 1 to over 100. Although designed for current shunt measurement, the circuit invites creative applications in measurement and level shifting.
Both the INA139-Q1 and INA169-Q1 are available in a TSSOP-8 package, and are specified for the –40°C to +125°C temperature range.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
