--- 产品详情 ---
| PGA/VGA | VGA |
| Number of channels (#) | 1 |
| BW @ Acl (MHz) | 600 |
| Vs (Max) (V) | 5.25 |
| Vs (Min) (V) | 4 |
| Acl, min spec gain (V/V) | 0.25 |
| Gain (Max) (dB) | 30 |
| Architecture | Fully Differential ADC Driver |
| Slew rate (Typ) (V/us) | 1600 |
| Operating temperature range (C) | -40 to 85 |
| Features | Digital Gain Set, Single-ended to Differential conversion |
- Adjustable Gain with a 42 dB Range
- Precise 6.02 dB Gain Steps
- Parallel 3 Bit Gain Control
- On Chip Register Gain Setting
- Fully Differential Signal Path
- Single Ended to Differential Capable
- 200? Input Impedance
- Small Footprint (4 mm x 4 mm) WQFN Package
Key Specifications
- 600 MHz bandwidth at 100? load
- 39 dBm OIP3 at 75 MHz, 200? load
- 26 dB to 38 dB maximum gain
- Selectable output impedance of 200? or 400?.
- 8.3 dB noise figure
- 5 ns gain step switching time
- 100 mA supply current
All trademarks are the property of their respective owners.
The LMH6514 is a high performance, digitally controlled variable gain amplifier (DVGA). It combines precision gain control with a low noise, ultra-linear, differential amplifier. Typically, the LMH6514 drives a high performance ADC in a broad range of mixed signal and digital communication applications such as mobile radio and cellular base stations where automatic gain control (AGC) is required to increase system dynamic range. When used in conjunction with a high speed ADC, system dynamic range can be extended by up to 42 dB.
The LMH6514 has a differential input and output allowing large signal swings on a single 5V supply. It is designed to accept signals from RF elements and maintain a terminated impedance environment. The input impedance is 200? resistive. The output impedance is either 200? or 400? and is user selectable. A unique internal architecture allows use with both single ended and differential input signals.
Input signals to the LMH6514 are scaled by a highly linear, digitally controlled attenuator with seven accurate 6 dB steps. The attenuator output provides the input signal for a high gain, ultra linear differential transconductor. The transconductor differential output current can be converted into a voltage by using the on-chip 200? or 400? loads. The transconductance gain is 0.1 Amp/Volt resulting in a maximum voltage gain of +32 dB when driving a 200? load, or 38 dB when driving the 400? load.
The LMH6514 operates over the industrial temperature range of ?40°C to +85°C. The LMH6514 is available in a 16-Pin, thermally enhanced, WQFN package.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
