--- 产品详情 ---
| Number of channels (#) | 2 |
| Vs (Max) (V) | 5.5 |
| Vs (Min) (V) | 2.5 |
| Input offset (+/-) (Max) (uV) | 1000 |
| Gain (Min) (V/V) | 5 |
| Gain (Max) (V/V) | 1000 |
| Noise at 1 kHz (Typ) (nV/rt (Hz)) | 100 |
| Features | Cost Optimized |
| CMRR (Min) (dB) | 80 |
| Input bias current (+/-) (Max) (nA) | 0.01 |
| Iq (Typ) (mA) | 0.04 |
| Bandwidth at min gain (Typ) (MHz) | 0.5 |
| Gain error (+/-) (Max) (%) | 0.1 |
| Operating temperature range (C) | -55 to 125 |
| Type | Resistor |
| Output swing headroom (to negative supply) (Typ) (V) | 0.025 |
| Output swing headroom (to positive supply) (Typ) (V) | -0.025 |
| Input common mode headroom (to negative supply) (Typ) (V) | 0.55 |
| Input common mode headroom (to positive supply) (Typ) (V) | -1.7 |
| Noise at 0.1 Hz-10 Hz (Typ) (uVpp) | 20 |
| Gain non-linearity (+/-) (Max) (%) | 0.01 |
- LOW QUIESCENT CURRENT: 40μA/channel Shut Down: < 1μA
- HIGH GAIN ACCURACY: G = 5, 0.02%, 2ppm/°C
- GAIN SET WITH EXTERNAL RESISTORS
- LOW OFFSET VOLTAGE: ±200μV
- HIGH CMRR: 94dB
- LOW BIAS CURRENT: 10pA
- BANDWIDTH: 500kHz, G = 5V/V
- RAIL-TO-RAIL OUTPUT SWING: (V+) - 0.02V
- WIDE TEMPERATURE RANGE: -55°C to +125°C
- SINGLE VERSION IN MSOP-8 PACKAGE AND DUAL VERSION IN TSSOP-14 PACKAGE
- APPLICATIONS
- INDUSTRIAL SENSOR AMPLIFIERS: Bridge, RTD, Thermistor, Position
- PHYSIOLOGICAL AMPLIFIERS: ECG, EEG, EMG
- A/D CONVERTER SIGNAL CONDITIONING
- DIFFERENTIAL LINE RECEIVERS WITH GAIN
- FIELD UTILITY METERS
- PCMCIA CARDS
- COMMUNICATION SYSTEMS
- TEST EQUIPMENT
- AUTOMOTIVE INSTRUMENTATION
All trademarks are the property of their respective owners.
The INA321 family is a series of rail-to-rail output, micropower CMOS instrumentation amplifiers that offer wide-range, single-supply, as well as bipolar-supply operation. The INA321 family provides low-cost, low-noise amplification of differential signals with micropower current consumption of 40μA. When shutdown, the INA321 has a quiescent current of less than 1μA. Returning to normal operations within nanoseconds, the shutdown feature makes the INA321 optimal for low-power battery or multiplexing applications.
Configured internally for 5V/V gain, the INA321 offers exceptional flexibility with user-programmable external gain resistors. The INA321 reduces common-mode error over frequency and with CMRR remaining high up to 3kHz, line noise and line harmonics are rejected.
The low-power design does not compromise on bandwidth or slew rate, making the INA321 ideal for driving sample Analog-to-Digital (A/D) converters as well as general-purpose applications. With high precision, low cost, and small packaging, the INA321 outperforms discrete designs, while offering reliability and performance.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
