--- 产品参数 ---
- 分辨率 12 Bits
- 采样率 20.8 / 15.2 / 12 Gsps
- 通道数 1 或 2
- 模拟输入带宽 5 GHz
- SNR 49.4 / 51.1 / 51.5 dBFS
- SFDR 68.7 / 70.6 / 65.6 dBc
- ENOB 7.9 / 8.2 / 8.2 b
- 数字输出接口 JESD204B
- 工作温度 -40 to 115°C
- 低功耗 6 / 5.3 / 4.8 W
- 封装 FCBGA484 (19mm x 19mm)
--- 数据手册 ---
--- 产品详情 ---
CAE2200s / CAE2300s / CAE2400s is a 12b RF Analog To-Digital Converter (ADC) with maximum sampling rate of 20.8GSPS / 15.2GSPS / 12GSPS in single channel mode, and with maximum sampling rate of 10.4GSPS / 7.6GSPS / 6GSPS in dual channel mode, and with maximum sampling rate of 5.2GSPS / 3.8GSPS / 3GSPS in quad channel mode.
The single / dual / quad channel mode can be configured by SPI setting, can be developed by flexible hardware to support multi-channels or wide
instantaneous bandwidth applications.
CAE2200s / CAE2300s / CAE2400s adopt high speed JESD204B output interface, with the operating junction temperature of -40 to 115°C, and the package of Flip-Chip BGA 484 pins (19mm x 19mm).
为你推荐
20.8 / 15.2 / 12 Gsps 12 位射频采样模数转换器(ADC)2026-04-18 19:15
产品型号:CAE2200S / CAE2300S / CAE2400S 分辨率:12 Bits 采样率:20.8 / 15.2 / 12 Gsps 通道数:1 或 2 模拟输入带宽:5 GHz SNR:49.4 / 51.1 / 51.5 dBFS -
CAE2X00系列评估板2025-08-04 16:31
产品型号:CAE2X00 EVM 分辨率:12 Bits 采样率:2.8Gsps-11.2Gsps 通道数:1 或 2 模拟输入带宽:5.2 GHz 数字输出接口:JESD204B -
4 / 2 / 1 GSPS 12 位 射频采样模数转换器(ADC)2025-02-17 11:42
产品型号:CAE2500 / CAE2600 / CAE2700 分辨率:12 Bits 采样率:4 / 2 / 1 GSPS 通道数:1 或 2 输入电压范围:0.8V (典型) 模拟输入带宽:3 GHz -
10.4 / 8 / 6 Gsps 12 位射频采样模数转换器(ADC)2025-02-11 17:20
产品型号:CAE2200 / CAE2300 / CAE2400 分辨率:12 Bits 采样率:10.4 / 8 / 6 Gsps 通道数:1 或 2 输入电压范围:0.8V (典型) 模拟输入带宽:5 GHz -
16位、8通道、200Ksps 同步采样ADC2024-07-30 10:21
产品型号:CAE1200 分辨率:16 Bits 采样率:200Ksps(每通道) 通道数:8通道(同步采样) 真双极性模拟输入:±10V、±5V、±2.5V 输入模式:模拟差分输入
国产高速ADC赋能UHF局放监测,实现电力核心采集芯片自主突破2026-09-11 15:30
发布|CAE1200+FPGA开发板2025-02-19 11:50
应用|16位8通道ADC - CAE1200用于电能质量监测,兼容AD76062024-08-06 12:32
CITE 2024精彩回顾|奇历士携自研高速/高精度ADC大放异彩2024-07-31 08:39
