企业号介绍
全部
  • 全部
  • 产品
  • 方案
  • 文章
  • 资料
  • 企业
巨匠机械
我们是做库存的 倍加福 施克 菲尼克斯 MTL 图尔克 总的库存有1千多万
98 内容数 3.1w 浏览量 35 粉丝
安全栅KFA6-STR-1.24.500
型号: KFA6-STR-1.24.500
--- 产品参数 ---
  • 连接终端 14、15
  • 额定电压90.253 48.63 Hz
  • B特征 16A
  • 输出量 连接电力铁路或7+,8-
  • 电流500 mA 60°C
  • 电偶隔离 电源/输出安全隔离
--- 产品详情 ---
Connectionterminals 14, 15
Rated voltage90 ... 253 V AC , 48 ... 63 Hz
Fusingback-up fuse :
B characteristic: 16 A
B characteristic: 10 A
B characteristic: 6 A
Power dissipation2.5 W
Output
ConnectionPower Rail or terminals 7+, 8-
Current500 mA at 60 °C (140 °F) , permanent short-circuit protection (electronic)
Output rated operating currentmax. 500 mA
Output voltage24 V DC
Galvanic isolation
Power supply/Outputsafe isolation acc. to DIN VDE 0106, rated insulation voltage 253 Veff
Indicators/settings
Display elementsLED
Labelingspace for labeling at the front
Directive conformity
Electromagnetic compatibility
 Directive 2014/30/EUEN 55022:2010 , EN 61000-4-2:2009 , EN 61000-4-3:2006+A1:2008 , EN 61000-4-4:2012 , EN 61000-4-5:2014 , EN 61000-4-6:2014 , EN 61000-4-11:2004 , EN 61000-6-2:2005+AC:2005 , EN 61000-6-3:2007+A1:2011
Low voltage
 Directive 2014/35/EUEN 60950-1:2006+A1:2010+A2:2013
Conformity
Insulation coordinationEN 50178
Galvanic isolationEN 50178
Degree of protectionIEC 60529
Ambient conditions
Ambient temperature-20 ... 60 °C (-4 ... 140 °F)
提示:以下是本篇文章正文内容,下面案例可供参考
一、产品描述
Mechanical specifications
Degree of protectionIP20
Connectionscrew terminals
Massapprox. 140 g
Dimensions20 x 119 x 115 mm (0.8 x 4.7 x 4.5 inch) (W x H x D) , housing type B2
Mountingon 35 mm DIN mounting rail acc. to EN 60715:2001
General information
Supplementary informationObserve the certificates, declarations of conformity, instruction manuals, and manuals where applicable. For information see www.pepperl-fuchs.com.
Classifications
SystemClasscode
ECLASS 11.027210119
ECLASS 10.0.127210119
ECLASS 9.027210119
ECLASS 8.027210119
ECLASS 5.127210119
ETIM 8.0EC002653
ETIM 7.0EC002653
ETIM 6.0EC002653
ETIM 5.0EC002542
UNSPSC 12.139121004
二、应用领域
示例:
• 工业控制领域:工业、控制设备美。
三、应用电路图
示例:
总结
提示:这里对文章进行总结:
例如:以上就是今天要讲的内容,本文仅仅简单介绍了XX产品的使用,我们提供了大量方案产品,欢迎联系,感谢您的关注。
为你推荐
  • Terminal Block for Cold Junction Compensation K-CJC-1BU2022-11-08 13:37
    产品型号:K-CJC-1BU 变送器位置:c 信号范围:4到20mA 大范围:1.0到21.5mA 常规变送器:0到3602 智能变送器:2500土10%
  • Terminal Block for Cold Junction Compensation K-CJC-BU2022-11-08 13:28
    产品型号:K-CJC-BU Number of :3 Core cross:max. 2.5 mm2 Color:blue Mass:approx. 5 g Dimensions:15.1 x 15 x 18 mm
  • SD07R2022-11-08 13:20
    产品型号:SD07R 变送器位置 : c 信号范围:4到20mA 大范围:1.0到21.5mA 常规变送器:0到3602 智能变送器:2500土10%
  • Solenoid Driver KFD0-SD2-Ex1.10452022-11-08 13:16
    产品型号:KFD0-SD2-Ex1.1045 信号类型 :数字输入 安全完整性等级:(SIL) SIL 2 连接端子:14 额定电压 : 103 功率耗散:1 W
  • SMART Transmitter Power Supply KFD2-STV5-Ex1-12022-11-08 13:09
    产品型号:KFD2-STV5-Ex1-1 信号类型:数字输入 安全完整性等级:(SIL) SIL 2 连接端子:14 额定电压:103 功率耗散 :1 W
  • Voltage Repeater KFD2-VR2-Ex1.50M2022-11-08 11:43
    产品型号:KFD2-VR2-Ex1.50M 信号类型:数字输入 安全完整性等级:(SIL) SIL 2 连接端子:14 额定电压:103 功率耗散:1 W
  • 电感式传感器 NBN8-18GM50-E22022-11-07 13:43
    产品型号:NBN8-18GM50-E2 开关功能:开关功能 输出类型:输出类型 额定工作距离:8 mm 安装:非齐平 输出极性:DC
  • 技术支持Emerson 475手操器2022-11-07 11:22
    产品型号:475手操器 Offline:脱机 Onling:在线 MEASURING :测量用的方式 Pressure:压力 Level:标准、水平的
  • 加拿大-AFP-正品全新原装-ELDV2-10-16MT-0030 AFP十通隔膜阀2022-11-07 11:09
    产品型号:ELDV2-10-16MT-0030 产地:加拿大 是否进口:是 订货号:3900 加工定制:否 货号:3900-03038
  • Current Driver/Repeater KFD0-CS-Ex2.51P2022-11-04 09:42
    产品型号:KFD0-CS-Ex2.51P Signal typ:Analog input/analog output Safety Int:SIL 2 Systematic:SC 3 Rated volt:loop powered Connection:terminals 12-, 11+; 8-, 10-, 9
