--- 产品参数 ---
- KCD2-SCD-1 1
--- 产品详情 ---
参数表节选:的技术参数 KCD2-SCD-1
| General specifications | ||
| Signal type | Analog output | |
| Functional safety related parameters | ||
| Safety Integrity Level (SIL) | SIL 2 | |
| Supply | ||
| Connection | Power Rail or terminals 9+, 10- | |
| Rated voltage | 19 ... 30 V DC | |
| Ripple | ≤ 10 % | |
| Rated current | ≤ 30 mA at 24 V | |
| Power dissipation | ≤ 600 mW at 20 mA and 500 Ω load | |
| Power consumption | ≤ 700 mW | |
| Input | ||
| Connection side | control side | |
| Connection | terminals 5-, 6+ | |
| Input signal | 4 ... 20 mA , limited to approx. 26 mA | |
| Input voltage | open loop voltage of the control system < 30 V | |
| Voltage drop | approx. 6 V at 20 mA | |
| Input resistance | > 100 kΩ, with field wiring open | |
| Output | ||
| Connection side | field side | |
| Connection | terminals 1+, 2- | |
| Voltage | ≥ 18 V at 20 mA | |
| Current | 4 ... 20 mA | |
| Load | 0 ... 900 Ω | |
| Ripple | 20 mV rms | |
| Transfer characteristics | ||
| Deviation | at 20 °C (68 °F), 4 ... 20 mA < 0.1 % of full scale, incl. non-linearity and hysteresis | |
| Influence of ambient temperature | < 2 µA/K (-20 ... 70 °C (-4 ... 158 °F)); < 4 µA/K (-40 ... -20 °C (-40 ... -4 °F)) | |
| Frequency range | bandwidth at 0.5 Vss signal 0 ... 3 kHz (-3 dB) | |
| Rise time | 10 to 90 % ≤ 10 ms | |
| Galvanic isolation | ||
| Input/Output | basic insulation according to IEC/EN 61010-1, rated insulation voltage 300 Veff | |
| Input/power supply | basic insulation according to IEC/EN 61010-1, rated insulation voltage 300 Veff | |
| Output/power supply | reinforced insulation according to IEC/EN 61010-1, rated insulation voltage 300 Veff | |
| Indicators/settings | ||
| Display elements | LED | |
| Labeling | space for labeling at the front | |
| Directive conformity | ||
| Electromagnetic compatibility | ||
| Directive 2014/30/EU | EN 61326-1:2013 (industrial locations) | |
| Conformity | ||
| Electromagnetic compatibility | NE 21:2017 EN 61326-3-2:2018 | |
| Degree of protection | IEC 60529 | |
| Ambient conditions | ||
| Ambient temperature | -40 ... 70 °C (-40 ... 158 °F) | |
| Mechanical specifications | ||
| Degree of protection | IP20 | |
| Connection | screw terminals | |
| Mass | approx. 100 g | |
| Dimensions | 12.5 x 124 x 114 mm (0.5 x 4.9 x 4.5 inch) (W x H x D) , housing type A2 | |
| Mounting | on 35 mm DIN mounting rail acc. to EN 60715:2001 | |
为你推荐
UB1000-18GM75-E01-V15 超声波传感器现货直发2022-12-20 13:31
产品型号:UB1000-18GM75-E01-V15 UB1000-18G:1 -
UMC3000-30H-E5-5M-3G-3D 超声波传感器现货直发2022-12-20 13:29
产品型号:UMC3000-30H-E5-5M-3G-3D UMC3000-30:1 -
UB6000-F42-I-V15 超声波传感器现货直发2022-12-20 13:21
产品型号:UB6000-F42-I-V15 UB6000-F42:1 -
UB500-18GM75-E01-V15 超声波传感器现货2022-12-20 13:20
产品型号:UB500-18GM75-E01-V15 UB500-18GM:1 -
UB5000-F42-UK-V95 超声波传感器现货直发2022-12-16 13:46
产品型号:UB5000-F42-UK-V95 UB5000-F42:1 -
UB500-F42S-U-V15 超声波传感器现货直发2022-12-16 13:44
产品型号:UB500-F42S-U-V15 UB500-F42S:1 -
UB4000-30GM-E4-V15 超声波传感器现货直发2022-12-16 13:42
产品型号:UB4000-30GM-E4-V15 UB4000-30G:1 -
UB2000-F42S-U-V15 超声波传感器现货直发2022-12-16 13:31
产品型号:UB2000-F42S-U-V15 UB2000-F42:1 -
UC2000-30GM-IUR2-V15-Y305942 传感器现货直发2022-12-16 13:27
产品型号:UC2000-30GM-IUR2-V15-Y305942 UC2000-30G:1 -
UB200-12GM-E5-V1 超声波传感器现货直发2022-12-16 13:23
产品型号:UB200-12GM-E5-V1 UB200-12GM:1
