--- 产品详情 ---
| Regulated outputs (#) | 7 |
| Vin (Min) (V) | 3 |
| Vin (Max) (V) | 5.5 |
| Iout (Max) (A) | 0.3 |
| Rating | Catalog |
| LDO | 7 |
| Iq (Typ) (mA) | 2 |
| Features | Comm Control |
| Configurability | Hardware configurable, Software configurable |
- Charger
- DC Adapter or USB Input
- Thermally Regulated Charge Current
- Under Voltage Lockout
- 50 to 950 mA Programmable Charge Current
- 3.0V to 5.5V Input Voltage Range
- Thermal Shutdown
- I2C-Compatible Interface for Controlling Charger, LDO Outputs and Enabling Audio Output
- LDO's 7 Low-Noise LDO’s
- 2 x 300 mA
- 3 x 150 mA
- 2 x 80 mA
- Audio
- Fully Differential Amplification
- Ability to Drive Capacitive Loads up to 100 pF
- No Output Coupling Capacitors, Snubber Networks or Bootstrap Capacitors Required
- Space-Efficient 32-pin 5 x 5 mm WQFN Package
All trademarks are the property of their respective owners.
The LP3921 is a fully integrated charger and multi-regulator unit with a fully differential Boomer audio power amplifier designed for CDMA cellular phones. The LP3921 has a high-speed serial interface which allows for the integration and control of a Li-Ion battery charger, 7 low-noise low-dropout (LDO) voltage regulators and a Boomer audio amplifier.
The Li-Ion charger integrates a power FET, reverse current blocking diode, sense resistor with current monitor output, and requires only a few external components. Charging is thermally regulated to obtain the most efficient charging rate for a given ambient temperature.
LDO regulators provide high PSRR and low noise ideally suited for supplying power to both analog and digital loads.
The Boomer Audio Amplifier is capable of delivering 1.1 watts of continuous average power to an 8? BTL load with less than 1% distortion (THD+N). Boomer Audio Power Amplifiers were designed specifically to provide high quality output power with a minimal amount of external components. The Boomer Audio Amplifier does not require output coupling capacitors or bootstrap capacitors, and therefore is ideally suited for mobile phone and other low voltage applications where minimal power consumption and part count is the primary requirement. The Boomer Audio Amplifier contains advanced pop & click circuitry which eliminates noises during turn-on and turn-off transitions.
为你推荐
TI数字多路复用器和编码器SN54HC1512022-12-23 15:12
TI数字多路复用器和编码器SN54LS1532022-12-23 15:12
TI数字多路复用器和编码器CD54HC1472022-12-23 15:12
TI数字多路复用器和编码器CY74FCT2257T2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC257A2022-12-23 15:12
TI数字多路复用器和编码器SN74LVC157A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS258A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS257A2022-12-23 15:12
TI数字多路复用器和编码器SN74ALS157A2022-12-23 15:12
TI数字多路复用器和编码器SN74AHCT1582022-12-23 15:12
如何利用运算放大器设计振荡电路?2023-08-09 08:08
【PCB设计必备】31条布线技巧2023-08-03 08:09
电动汽车直流快充方案设计【含参考设计】2023-08-03 08:08
Buck电路的原理及器件选型指南2023-07-31 22:28
100W USB PD 3.0电源2023-07-31 22:27
千万不要忽略PCB设计中线宽线距的重要性2023-07-31 22:27
基于STM32的300W无刷直流电机驱动方案2023-07-06 10:02
上新啦!开发板仅需9.9元!2023-06-21 17:43
参考设计 | 2KW AC/DC数字电源方案2023-06-21 17:43
千万不能小瞧的PCB半孔板2023-06-21 17:34
