数据: TPS624xx-Q1 Automotive 2.25-MHz Fixed VOUT Dual Step-Down Converter 数据表
TPS624xx-Q1系列器件是同步双路降压DC-DC转换器,适用于高级驾驶员辅助系统(ADAS)等汽车应用。它们提供两个独立的输出电压轨,由标准3.3V或5V电压轨供电,具有固定输出电压,优化用于为ADAS相机模块中的CMOS成像器或串行器 - 解串器供电。
EasyScale™串行接口允许运行期间的输出电压修改。固定输出电压版本TPS624xx-Q1支持低功耗处理器的引脚控制简单动态电压调节。
TPS624xx-Q1系列器件工作在2.25-MHz固定开关频率,固定功率-save模式在轻负载电流下工作,以在整个负载电流范围内保持高效率。对于低噪声应用,可以通过将MODE /DATA引脚拉高来强制器件进入固定频率PWM模式。关断模式可将电流消耗降至1.2μA(典型值)。这些器件允许使用小型电感器和电容器来实现小尺寸的解决方案。
所有商标均为其各自所有者的财产。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS62407-Q1 | TPS62400-Q1 | TPS62410-Q1 | TPS62420-Q1 | TPS62423-Q1 | TPS62424-Q1 |
| 2.5 | 2.5 | 2.5 | 2.5 | 2.5 | 2.5 |
| 6 | 6 | 6 | 6 | 6 | 6 |
| 1.225 | 0.6 | 0.6 | 0.6 | 1.2 | 1.1 |
| 1.225 | 6 | 6 | 6 | 1.5 | 1.3 |
| 0.4 | 0.4 | 0.8 | 0.6 | 0.8 | 0.8 |
| 2 | 2 | 2 | 2 | 2 | 2 |
| 2000 | 2000 | 2250 | 2250 | 2000 | 2000 |
| 2500 | 2500 | 2250 | 2250 | 2500 | 2500 |
| 0.032 | 0.032 | 0.032 | 0.032 | 0.032 | 0.032 |
| Dynamic Voltage Scaling Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Multiple Outputs Over Current Protection Synchronous Rectification UVLO Fixed | Dynamic Voltage Scaling Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification | Dynamic Voltage Scaling Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification | Dynamic Voltage Scaling Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification | Dynamic Voltage Scaling Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Multiple Outputs Over Current Protection Synchronous Rectification | Dynamic Voltage Scaling Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Multiple Outputs Over Current Protection Synchronous Rectification UVLO Fixed |
| Voltage Mode | Voltage Mode | Voltage Mode | Voltage Mode | Voltage Mode | Voltage Mode |
| 100 | 100 | 100 | 100 | 100 | 100 |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| Automotive | Automotive | Automotive | Automotive | Automotive | Automotive |
| VSON | VSON | VSON | VSON | VSON | VSON |
