LM46000稳压器是一款易于使用的同步降压直流/直流转换器,能够驱动高达500mA的负载电流,输入电压范围为3.5 V至60V.LM46000以极小的解决方案尺寸提供出色的效率,输出精度和压降电压。扩展系列产品能够以引脚到引脚兼容封装提供1A和2A负载电流选项。采用峰值电流模式控制来实现简单控制环路补偿和逐周期电流限制。可选功能包括可编程开关频率,同步,电源正常标志,精确使能,内部软启动,可扩展软启动和跟踪,可为各种应用提供灵活易于使用的平台。轻载时的断续传导和自动频率调制可提升轻载效率。此系列只需要很少的外部组件,而且引脚排列可实现简单且优化的PCB布局。保护功能包括热关断,V CC 欠压锁定,逐周期电流限制和输出短路保护.LM46000器件采用16引脚引线式HTSSOP(PWP)封装(6.6mm ×5.1mm×1.2mm),引线间距为0.65mm。与LM46001,LM46002,LM43603,LM43602,LM43601和LM43600引脚对引脚兼容。
所有商标均为其各自的商标。拥有者。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| LM46000 | LM5165 | LM5166 | LMR36006 | LMR36015 |
| 3.5 | 3 | 3 | 4.2 | 4.2 |
| 60 | 65 | 65 | 60 | 60 |
| 1 | 1.23 | 1.23 | 1 | 1 |
| 28 | 65 | 65 | 57 | 57 |
| 0.5 | 0.15 | 0.5 | 0.6 | 1.5 |
| 1 | 1 | 1 | 1 | 1 |
| 200 | 50 | 50 | 1000 | 400 |
| 2200 | 600 | 600 | 2100 | 1000 |
| 0.024 | 0.01 | 0.01 | 0.023 | 0.023 |
| Enable Frequency Synchronization Light Load Efficiency Power Good Synchronous Rectification Tracking | Adjustable Current Limit Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification UVLO Adjustable | Adjustable Current Limit Enable Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification UVLO Adjustable | Enable Light Load Efficiency Over Current Protection Power Good Pre-Bias Start-Up Synchronous Rectification Wettable Flanks Package | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Power Good Pre-Bias Start-Up Synchronous Rectification Wettable Flanks Package |
| Current Mode | Constant on-time (COT) | Constant on-time (COT) | Current Mode | Current Mode |
| 99 | 100 | 100 | 98 | 98 |
| -40 to 125 | -40 to 150 | -40 to 150 | -40 to 150 | -40 to 150 |
| Catalog | Catalog | Catalog | Catalog | Catalog |
| HTSSOP | VSON | VSON | VQFN-HR | VQFN-HR |
| 无样片 |
