TPS51313是一款针对低压负载点应用的易于使用的,完全集成,同步降压转换器。它被设计成符合NVIDIA OpenVreg类型0 D-CAP2模式适应,恒定接通时间控制频率1MHz)可在使用全陶瓷输出电容器设计时实现小封装尺寸并提供一个低外部组件数量。此器件还在轻负载条件下特有自动跳跃功能,预偏置启动和内部固定软启动时间。当器件被禁用时,输出电容器通过内部电阻器放电.TPS51313采用3mm×3mm,10引脚DRC封装(符合RoHs环保标准且无铅),额定温度范围为-10°C至85°C。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS51313 | TPS51312 | TPS53311 | TPS53313 |
| 3.1 | 3.1 | 2.9 | 4.5 |
| 5.5 | 5.5 | 6 | 16 |
| 0.6 | 0.6 | 0.6 | 0.6 |
| 3.3 | 3.3 | 4.2 | 10 |
| 3 | 3 | 3 | 6 |
| 1 | 1 | 1 | 1 |
| 1000 | 900 | 1100 | 250 |
| 1000 | 900 | 1100 | 1500 |
| 0.8 | 0.8 | 0.32 | 0.32 |
| Enable Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Light Load Efficiency Output Discharge Phase Interleaving Power Good Pre-Bias Start-Up Synchronous Rectification | Enable Light Load Efficiency Output Discharge Power Good Pre-Bias Start-Up Synchronous Rectification |
| D-CAP2 | D-CAP2 | Voltage Mode | Voltage Mode |
| 90 | 90 | 99 | 99 |
| -10 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
| Catalog | Catalog | Catalog | Catalog |
| VSON | VSON | VQFN | VQFN |
