TPS6226x器件是针对电池供电应用而优化的高效同步降压DC-DC转换器。它可从单个锂离子电池提供高达600 mA的输出电流,是移动电话和其他便携式应用的理想选择。
该器件具有2 V至6 V的宽输入电压范围,支持由具有扩展电压范围的锂离子电池供电的应用,2节和3节碱性电池,3.3 V和5 V输入电压轨。
TPS6226x工作在2.25MHz固定开关频率,并在轻负载电流下进入省电模式工作,以在整个负载电流范围内保持高效率。
省电模式针对低输出电压纹波进行了优化。对于低噪声应用,可以通过将MODE引脚拉高来强制器件进入固定频率PWM模式。在关断模式下,电流消耗降至1μA以下。 TPS6226x允许使用小型电感器和电容器来实现小尺寸解决方案。
TPS6226x采用非常小的2×2mm 6引脚SON封装。
| Vin (Min) (V) |
| Vin (Max) (V) |
| Vout (Min) (V) |
| Vout (Max) (V) |
| Iout (Max) (A) |
| Regulated Outputs (#) |
| Switching Frequency (Min) (kHz) |
| Switching Frequency (Max) (kHz) |
| Iq (Typ) (mA) |
| Features |
| Control Mode |
| Duty Cycle (Max) (%) |
| Operating Temperature Range (C) |
| Rating |
| Package Group |
| TPS62260-Q1 | TPS62231-Q1 | TPS622314-Q1 | TPS62242-Q1 | TPS62243-Q1 | TPS62244-Q1 | TPS62290-Q1 | TPS62293-Q1 | TPS62590-Q1 |
| 2 | 2.05 | 2.05 | 2 | 2 | 2 | 2.3 | 2.3 | 2.5 |
| 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 | 6 |
| 0.6 | 1.8 | 1.5 | 1.2 | 1.8 | 1.25 | 0.6 | 1.8 | 0.75 |
| 6 | 1.8 | 1.5 | 1.2 | 1.8 | 1.25 | 6 | 1.8 | 6 |
| 0.6 | 0.5 | 0.5 | 0.3 | 0.3 | 0.3 | 1 | 1 | 1 |
| 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 | 1 |
| 2250 | 3000 | 3000 | 2250 | 2250 | 2250 | 2250 | 2250 | 2000 |
| 2250 | 3000 | 3800 | 2250 | 2250 | 2250 | 2250 | 2250 | 2500 |
| 0.015 | 0.022 | 0.022 | 0.015 | 0.015 | 0.015 | 0.015 | 0.015 | 0.015 |
| Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification UVLO Fixed | Enable Light Load Efficiency Over Current Protection Synchronous Rectification UVLO Fixed | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification | Enable Forced Pulse Width Modulation (FPWM) Mode Light Load Efficiency Synchronous Rectification |
| Voltage Mode | Constant on-time (COT) DCS-Control | Voltage Mode DCS-Control | Voltage Mode | Voltage Mode | Voltage Mode | Voltage Mode | Voltage Mode | Voltage Mode |
| 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 | 100 |
| -40 to 105 -40 to 85 | -40 to 105 | -40 to 105 | -40 to 115 | -40 to 125 | -40 to 125 | -40 to 105 -40 to 85 | -40 to 105 | -40 to 105 |
| Automotive | Automotive | Automotive | Automotive | Automotive | Automotive | Automotive | Automotive | Automotive |
| SOT-23-THIN WSON | SON | SON | SOT-23-THIN | SOT-23-THIN | SOT-23-THIN | WSON | WSON | WSON |
