OPA376-Q1系列是采用的新一代低噪声运算放大器的典型代表,同时拥有出色的直流精度和交流性能。该器件具有轨到轨输出,低偏移(最大值为25μV),低噪声(7.5nV /√ Hz ),950μA的静态电流(最大值)和5.5MHz带宽,对于各类精密和便携式应用极具吸引力。此外,该器件的电源范围相当宽,电源抑制比(PSRR)优异,因此对于不经稳压而直接由电池供电运行的应用而言极具吸引力。
OPA376-Q1(单通道)采用MicroSIZE Sc70-5,小外形尺寸晶体管(SOT)-23-5与小外形尺寸集成电路(SOIC)-8封装.OPA2376-Q1 (双通道)采用SOIC-8和超薄小外形尺寸(VSSOP)-8封装.OPA4376-Q1(四通道)采用薄型小外形尺寸(TSSOP)-14封装。所有器件版本的额定工作温度范围均为-40°C至+ 125°C。
<小>所有商标是其相应所有者的财产。
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| GBW (Typ) (MHz) |
| Slew Rate (Typ) (V/us) |
| Rail-to-Rail |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Offset Drift (Typ) (uV/C) |
| Iq per channel (Typ) (mA) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| CMRR (Typ) (dB) |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Input Bias Current (Max) (pA) |
| Output Current (Typ) (mA) |
| Features |
| Architecture |
| OPA2376-Q1 | OPA2376 | OPA376 | OPA376-Q1 | OPA4376 | OPA4376-Q1 |
| 2 | 2 | 1 | 1 | 4 | 4 |
| 2.2 | 2.2 | 2.2 | 2.2 | 2.2 | 2.2 |
| 5.5 | 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
| 2 | 2 | 2 | 2 | 2 | 2 |
| In Out | In Out | In Out | In Out | In Out | In Out |
| 0.025 | 0.025 | 0.025 | 0.025 | 0.025 | 0.025 |
| 0.32 | 0.32 | 0.32 | 0.32 | 0.32 | 0.32 |
| 0.76 | 0.76 | 0.76 | 0.76 | 0.76 | 0.76 |
| 7.5 | 7.5 | 7.5 | 7.5 | 7.5 | 7.5 |
| 90 | 90 | 90 | 90 | 90 | 90 |
| Automotive | Catalog | Catalog | Automotive | Catalog | Automotive |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| SOIC VSSOP | DSBGA SOIC VSSOP | SC70 SOIC SOT-23 | SOT-23 | TSSOP | TSSOP |
| 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | See datasheet (DSBGA) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 5SC70: 4 mm2: 2.1 x 2(SC70) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) |
| 10 | 10 | 10 | 10 | 10 | 10 |
| 30 | 30 | 30 | 30 | 30 | 30 |
| EMI Hardened | EMI Hardened Small Size | Small Size EMI Hardened | EMI Hardened | EMI Hardened | EMI Hardened |
| CMOS | CMOS | CMOS | CMOS | CMOS | CMOS |
