THS4061和THS4062是通用型,单/双路,高速电压反馈放大器,适用于广泛的应用,包括视频,通信和成像。这些器件具有非常好的交流性能,带宽为180 MHz,压摆率为400 V /μs,建立时间为40 ns(0.1%)。对于反相和同相配置,THS4061 /2在所有增益下都是稳定的。这些放大器具有115 mA的高输出驱动能力,每通道仅消耗7.8 mA电源电流。 0.02%/0.02°的低差分增益/相位误差和75 MHz的宽0.1 dB平坦度可以获得出色的专业视频效果。对于要求低失真的应用,THS4061 /2非常适合在f = 1 MHz时总谐波失真为72 dBc。
PowerPAD是Texas Insruments Incorporated的商标。
| Architecture |
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| BW @ Acl (MHz) |
| Acl, min spec gain (V/V) |
| Slew Rate (Typ) (V/us) |
| Vn at Flatband (Typ) (nV/rtHz) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Iq per channel (Typ) (mA) |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Rail-to-Rail |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| CMRR (Typ) (dB) |
| Input Bias Current (Max) (pA) |
| Offset Drift (Typ) (uV/C) |
| GBW (Typ) (MHz) |
| Output Current (Typ) (mA) |
| 2nd Harmonic (dBc) |
| 3rd Harmonic (dBc) |
| @ MHz |
| THS4061 | THS4062 |
| Bipolar Voltage FB | Bipolar Voltage FB |
| 1 | 2 |
| 9 | 9 |
| 32 | 32 |
| 180 | 180 |
| 1 | 1 |
| 400 | 400 |
| 14.5 | 14.5 |
| 14.5 | 14.5 |
| 7.8 | 7.8 |
| 8 | 8 |
| No | No |
| N/A | N/A |
| Catalog | Catalog |
| -40 to 85 0 to 70 | -40 to 85 0 to 70 |
| MSOP-PowerPAD SOIC | MSOP-PowerPAD SOIC |
| 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) | 8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD) 8SOIC: 29 mm2: 6 x 4.9(SOIC) |
| 110 | 110 |
| 3000000 | 3000000 |
| 15 | 15 |
| 180 | 180 |
| 115 | 115 |
| 72 | 72 |
| 72 | 72 |
| 1 | 1 |
