数据: LMV34x Rail-to-Rail Output CMOS Operational Amplifiers With Shutdown 数据表
LMV34x器件分别是单通道,双通道和四通道CMOS运算放大器,具有低电压,低功耗和轨到轨输出摆幅功能。 PMOS输入级提供1 pA(典型值)的超低输入偏置电流和0.25 mV(典型值)的偏移电压。单电源放大器专为低压(2.7 V至5 V)工作而设计,具有较宽的共模输入电压范围,通常从正电源轨延伸至-0.2 V至0.8 V. LMV341(单个)还提供关闭( SHDN )引脚,可用于禁用器件。在关断模式下,电源电流降至33 nA(典型值)。该系列的其他特性是10-kHz的20-nV /√ Hz 电压噪声,1-MHz单位增益带宽,1-V /μs压摆率每个通道的电流消耗为100μA。
LMV341采用SOT-23封装和小型SC70封装,适用于大多数空间受限的应用。 LMV342双器件采用标准SOIC和VSSOP封装。扩展的工业温度范围为-40°C至125°C,使这些器件适用于各种商业和工业环境。
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| GBW (Typ) (MHz) |
| Slew Rate (Typ) (V/us) |
| Rail-to-Rail |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Iq per channel (Typ) (mA) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Offset Drift (Typ) (uV/C) |
| Features |
| Input Bias Current (Max) (pA) |
| CMRR (Typ) (dB) |
| Output Current (Typ) (mA) |
| Architecture |
| LMV342 | LMV341 | LMV341-Q1 | LMV344 | LMV344-Q1 |
| 2 | 1 | 1 | 4 | 4 |
| 2.5 | 2.5 | 2.5 | 2.5 | 2.5 |
| 5.5 | 5.5 | 5.5 | 5.5 | 5.5 |
| 1 | 1 | 1 | 1 | 1 |
| 1 | 1 | 1 | 1 | 1 |
| In to V- Out | In to V- Out | In to V- Out | In to V- Out | In to V- Out |
| 4 | 4 | 4 | 5 | 4 |
| 0.107 | 0.107 | 0.107 | 0.107 | 0.107 |
| 39 | 39 | 39 | 39 | 39 |
| Catalog | Catalog | Automotive | Catalog | Automotive |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 85 |
| SOIC VSSOP | SC70 SOT-23 | SC70 SOT-23 | SOIC TSSOP | TSSOP |
| 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 6SC70: 4 mm2: 2.1 x 2(SC70) 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 6SC70: 4 mm2: 2.1 x 2(SC70) 6SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) |
| 1.9 | 1.9 | 1.9 | 1.9 | 1.9 |
| N/A | Shutdown Small Size | Shutdown Small Size | N/A | N/A |
| 200 | 200 | 200 | 200 | 200 |
| 86 | 86 | 86 | 86 | 86 |
| 75 | 75 | 75 | 75 | 75 |
| CMOS | CMOS | CMOS | CMOS | CMOS |
