TLV27x在扩展的汽车温度范围内将最低工作电源电压降至2.7 V,同时增加了轨到轨输出摆幅功能。这使其成为TLC27x系列的理想替代产品,适用于轨到轨输出摆幅必不可少的应用。 TLV27x还提供3 MHz带宽,仅550μA。
与TLC27x一样,TLV27x完全适用于5 V和±5 V电源。推荐的最大电源电压为16 V,允许器件通过各种可充电电池工作(±8 V电源电压低至±1.35 V)。
CMOS输入可用于高阻抗传感器接口具有较低的电压操作,是电池供电应用中TLC27x的有吸引力的替代方案。
2.7V工作使其兼容锂离子电池供电系统和许多工作电源电压范围微功率微控制器现已上市,包括德州仪器MSP430。
Hz
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| GBW (Typ) (MHz) |
| Slew Rate (Typ) (V/us) |
| Rail-to-Rail |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Iq per channel (Typ) (mA) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Offset Drift (Typ) (uV/C) |
| Features |
| Input Bias Current (Max) (pA) |
| CMRR (Typ) (dB) |
| Output Current (Typ) (mA) |
| Architecture |
| TLV271-Q1 | TLV271 | TLV272 | TLV272-Q1 | TLV274 | TLV274-Q1 |
| 1 | 1 | 2 | 2 | 4 | 4 |
| 2.7 | 2.7 | 2.7 | 2.7 | 2.7 | 2.7 |
| 16 | 16 | 16 | 16 | 16 | 16 |
| 3 | 3 | 3 | 3 | 3 | 3 |
| 2.1 | 2.1 | 2.1 | 2.1 | 2.1 | 2.1 |
| In to V- Out | In to V- Out | In to V- Out | In to V- Out | In to V- Out | In to V- Out |
| 5 | 5 | 5 | 5 | 5 | 5 |
| 0.55 | 0.55 | 0.55 | 0.55 | 0.55 | 0.55 |
| 39 | 39 | 39 | 39 | 39 | 39 |
| Automotive | Catalog | Catalog | Automotive | Catalog | Automotive |
| -40 to 125 | -40 to 125 0 to 70 | -40 to 125 0 to 70 | -40 to 125 | -40 to 125 0 to 70 | -40 to 125 |
| SOIC SOT-23 | PDIP SOIC SOT-23 | PDIP SOIC VSSOP | SOIC | PDIP SOIC TSSOP | SOIC TSSOP |
| 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | See datasheet (PDIP) 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) | See datasheet (PDIP) 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) | 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) |
| 2 | 2 | 2 | 2 | 2 | 2 |
| N/A | N/A | N/A | N/A | N/A | N/A |
| 60 | 60 | 60 | 60 | 60 | 60 |
| 80 | 80 | 80 | 80 | 80 | 80 |
| 7 | 7 | 7 | 7 | 7 | 7 |
| CMOS | CMOS | CMOS | CMOS | CMOS | CMOS |
