OPA2364和OPA4364是高性能CMOS运算放大器,针对低压单电源工作进行了优化。这些微型低成本放大器设计用于1.8 V(±0.9 V)至5.5 V(±2.75 V)的单电源。应用包括电池供电系统中的传感器放大和信号调理。
OPAx364系列提供出色的CMRR,无需与传统互补输入级相关的分频。这使得驱动模数(A /D)转换器具有出色的性能,而不会降低差分线性度和总谐波失真(THD)。输入共模范围包括负电源和正电源。输出电压摆幅在电压轨的10 mV范围内。
双通道版本采用SO-8封装,四通道封装采用SO-14封装。所有版本的工作温度范围均为?40°C至125°C。
| Number of Channels (#) |
| Total Supply Voltage (Min) (+5V=5, +/-5V=10) |
| Total Supply Voltage (Max) (+5V=5, +/-5V=10) |
| GBW (Typ) (MHz) |
| Slew Rate (Typ) (V/us) |
| Rail-to-Rail |
| Vos (Offset Voltage @ 25C) (Max) (mV) |
| Iq per channel (Typ) (mA) |
| Vn at 1kHz (Typ) (nV/rtHz) |
| Rating |
| Operating Temperature Range (C) |
| Package Group |
| Package Size: mm2:W x L (PKG) |
| Offset Drift (Typ) (uV/C) |
| Features |
| Input Bias Current (Max) (pA) |
| CMRR (Typ) (dB) |
| Output Current (Typ) (mA) |
| Architecture |
| OPA4364-Q1 | OPA2364 | OPA364 | OPA4364 |
| 4 | 2 | 1 | 4 |
| 1.8 | 1.8 | 1.8 | 1.8 |
| 5.5 | 5.5 | 5.5 | 5.5 |
| 7 | 7 | 7 | 7 |
| 5 | 5 | 5 | 5 |
| In Out | In Out | In Out | In Out |
| 3 | 2.5 | 2.5 | 2.5 |
| 0.65 | 0.65 | 0.65 | 0.65 |
| 17 | 17 | 17 | 17 |
| Automotive | Catalog | Catalog | Catalog |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| SOIC | SOIC VSSOP | SOIC SOT-23 | SOIC TSSOP |
| 14SOIC: 52 mm2: 6 x 8.65(SOIC) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 8VSSOP: 15 mm2: 4.9 x 3(VSSOP) | 8SOIC: 29 mm2: 6 x 4.9(SOIC) 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) | 14SOIC: 52 mm2: 6 x 8.65(SOIC) 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) |
| 3 | 3 | 3 | 3 |
| N/A | Shutdown | N/A | Shutdown |
| 10 | 10 | 10 | 10 |
| 90 | 90 | 90 | 90 |
| 45 | 45 | 45 | 45 |
| CMOS | CMOS | CMOS | CMOS |
