数据: Secondary Side Post Regulator/DC-DC Converter with Power-up/Power-down Tracking 数据表
LM5115A控制器包含使用次级侧后置调节(SSPR)技术产生多个跟踪输出所需的所有功能。 SSPR技术从隔离电源转换器的次级侧开关波形开发出高效且良好调节的辅助输出。 LM5115A还可以用作独立的DC /DC同步降压控制器(参见章节)。通过主通道占空比的前沿脉冲宽度调制(PWM)实现辅助输出电压的调节。前沿调制与主输出的电流模式或电压模式控制兼容。 LM5115A驱动外部高端和低端NMOS电源开关,配置为同步降压稳压器。电流检测放大器提供过载保护,可在宽共模输入范围内工作。其他功能包括低压差(LDO)偏置稳压器,误差放大器,精密基准,栅极信号的自适应死区时间控制和热关断。
所有商标均为其各自所有者的财产。
| Topology |
| Control Method |
| Vin (Min) (V) |
| Vin (Max) (V) |
| Frequency (Max) (kHz) |
| UVLO Thresholds On/Off (V) |
| Duty Cycle (Max) (%) |
| Gate Drive (Typ) (A) |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Pin/Package |
| LM5115A | LM25115 | LM25115A | LM5025 | LM5115 |
| Synchronous secondary-side post-regulator | Synchronous secondary-side post-regulator | Synchronous secondary-side post-regulator | Active-Clamp Forward Forward | Synchronous secondary-side post-regulator |
| ValleyCurrent | Current Voltage | ValleyCurrent | Feedforward Voltage | Current Voltage |
| 4.5 | 4.5 | 4.5 | 13 | 4.5 |
| 75 | 42 | 42 | 90 | 75 |
| 1000 | 1000 | 1000 | 1000 | 1000 |
| 4.25/4.0 | 4.15/4.0 | 4.15/4.0 | Programmable/2.5V | 4.25/4.0 |
| 85 | 85 | 85 | 80 | 85 |
| 2.5 | 2.5 | 2.5 | 3 | 2.5 |
| Soft Start | Frequency Synchronization Soft Start Synchronization Pin Thermal Shutdown | Frequency Synchronization Soft Start Synchronization Pin Thermal Shutdown | Current Limiting HV Start-up Leading Edge Blanking Soft Start Thermal Shutdown | Frequency Synchronization |
| Catalog | Catalog | Catalog | Catalog | Catalog |
| -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 | -40 to 125 |
| 16TSSOP | 16TSSOP 16WSON | 16TSSOP | 16TSSOP 16WSON | 16TSSOP 16WSON |
