UC1526A系列是性能改进的脉冲宽度调制器电路,可直接替换所有应用中的等效非\ x93A \ x94版本。通过几个显着的改进已经增强了更高频率的操作,包括:具有更少的最小死区时间的更精确的振荡器,减少的电路延迟(特别是在电流限制中),以及具有可忽略的交叉传导电流的改进的输出级。其他改进包括采用精密带隙基准发生器,降低总电源电流以及增加热关断保护。
除了这些改进之外,UC1526A系列还具有欠压锁定,软启动,数字限流,双脉冲抑制逻辑和可调死区时间等保护功能。为了便于连接,所有数字控制端口都与TTL兼容,具有低电平有效逻辑。
通过连接V IN ,V C 和V REF <,可以对\ x93logic level \ x94应用程序进行5伏(5V)操作/sub>到精密5V输入电源。有关其他信息,请咨询工厂。
| Topology |
| Control Method |
| Vin (Min) (V) |
| Vin (Max) (V) |
| Frequency (Max) (kHz) |
| UVLO Thresholds On/Off (V) |
| Duty Cycle (Max) (%) |
| Gate Drive (Typ) (A) |
| Features |
| Rating |
| Operating Temperature Range (C) |
| Pin/Package |
| UC3526A | UC3524 | UC3524A | UC3525A | UC3525B |
| Boost Buck Flyback Forward Full-Bridge Half-Bridge Push-Pull | Boost Flyback Forward Full-Bridge Half-Bridge Push-Pull | Boost Buck Flyback Forward Full-Bridge Half-Bridge Push-Pull | Boost Buck Flyback Forward Full-Bridge Half-Bridge Push-Pull | Boost Buck Flyback Forward Full-Bridge Half-Bridge Push-Pull |
| Voltage | Voltage | Voltage | Voltage | Voltage |
| 7 | 7.5 | 7.5 | 7 | 7 |
| 40 | 40 | 40 | 40 | 40 |
| 600 | 450 | 450 | 500 | 500 |
| 7/6.8 | 7.5/7 | 7.5/7 | 7.0/6.5 | 7.0/6.5 |
| 50 | 90 | 50 | 49 | 49 |
| 0.2 | 0.1 | 0.2 | 0.4 | 0.4 |
| Adjustable Switching Frequency Dead Time Control Error Amplifier Multi-topology Soft Start Synchronization Pin | Adjustable Switching Frequency Error Amplifier Multi-topology Soft Start Synchronization Pin | Adjustable Switching Frequency Error Amplifier Multi-topology Soft Start Synchronization Pin | Adjustable Switching Frequency Current Limiting Dead Time Control Error Amplifier Multi-topology Soft Start Synchronization Pin | Adjustable Switching Frequency Current Limiting Dead Time Control Error Amplifier Multi-topology Soft Start Synchronization Pin |
| Catalog | Catalog | Catalog | Catalog | Catalog |
| 0 to 70 | 0 to 70 | 0 to 70 | 0 to 70 | 0 to 70 |
| 18PDIP 18SOIC | 16SOIC 16SOIC | 16PDIP 16SOIC | 16PDIP 16SOIC | 16PDIP 16SOIC |
