TSU6712是具有阻抗检测的多重SP4T开关。这个开关特有阻抗检测,这一功能能够检测通过DP和DM附件的多种配件。通过使用I 2 C对TSU6712进行完全控制,并能够使得USB数据,立体声和单声道音频,视频使用一个共同的连接端口。
这个设备通过附加的VBAT或者VBUS进行供电。这个开关可以用I 2 C进行控制。当USB,UART JIG线缆在开发和生产期间被用来进行测试时,JIG和BOOT针脚启用。
Protocols |
Configuration |
Number of Channels (#) |
VCC (Min) (V) |
VCC (Max) (V) |
Ron (Typ) (Ohms) |
Input/Ouput Voltage (Min) (V) |
Input/Ouput Voltage (Max) (V) |
ICC (Max) (uA) |
Bandwidth (MHz) |
ESD HBM (Typ) (kV) |
Operating Temperature Range (C) |
Package Size: mm2:W x L (PKG) |
Package Group |
ICC (Typ) (uA) |
Input/Output OFF-state Capacitance (Typ) (pF) |
Input/Output ON-state Capacitance (Typ) (pF) |
Off Isolation (Typ) (dB) |
Ron (Max) (Ohms) |
Ron Channel Match (Max) (Ω) |
Turn off Time (Disable) (Max) (ns) |
Turn on Time (Enable) (Max) (ns) |
TSU6712 | TSU5511 | TSU5611 | TSU6111 | TSU6111A | TSU6721 | TSU8111 |
USB 2.0 MHL UART Analog Audio |
USB 2.0 Analog Audio UART |
USB 2.0 UART |
USB 2.0 UART |
1:4 SP4T | 1:3 SP3T | 1:3 SP3T | 1:2 SPDT | 1:2 SPDT | 1:3 SP3T | 1:2 SPDT |
2 | 2 | 2 | 2 | 2 | 2 | 2 |
3 | 2.8 | 2.8 | 3 | 3 | 3 | 1.65 |
6.5 | 6.7 | 6.7 | 6.5 | 6.5 | 6.5 | 6.5 |
8 | 4.5 | 4.5 | 8 | 8 | 6 | 8 |
-0.8 | -1.3 | 0 | 0 | -1.5 | 0 | |
3.6 | 3.6 | 3.6 | 3.6 | 3.6 | 3.6 | |
600 | 70 | See data sheet | 75 | 75 | 155 | 150 |
510 | 830 | 830 | 920 | 920 | 510 | 820 |
1.5 | 2 | 1.5 | 2 | 5 | 4 | 12 |
-40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 | -40 to 85 |
See datasheet (DSBGA) | See datasheet (DSBGA) | See datasheet (DSBGA) | 16UQFN: 5 mm2: 1.8 x 2.6(UQFN) | 16UQFN: 5 mm2: 1.8 x 2.6(UQFN) | See datasheet (DSBGA) | See datasheet (DSBGA) |
DSBGA | DSBGA | DSBGA | UQFN | UQFN | DSBGA | DSBGA |
60 | ||||||
10 | 6.5 | 7 | 7 | 7 | 7.5 | |
11 | 9 | 9 | 9 | 9 | 8.6 | |
-24 | -20 | -75 | -26 | -26 | -26 | -36 |
15 | 10 | 8.8 | 15 | 15 | 11 | |
1 | 1.5 | 2 | 2 | 1 | ||
95000 | 95000 | 95000 | 100000 | 57000 | ||
2500 | 3500 | 3500 | 130000 | 52000 | ||
