TS3DV416 适用于 DVI/HDMI 应用领域的 4 通道差动 8:16 Mux 开关
数据:
TS3DV416是一款16位至8位多路复用器/多路分解器数字视频开关,具有单选(SEL)输入。 SEL控制多路复用器/多路分解器的数据路径。
器件提供低且平坦的导通电阻(r on )和良好的导通状态电阻匹配。低输入/输出电容,高带宽,低偏斜和通道间低串扰使该器件适用于各种数字视频应用,如DVI和HDMI。
特性
  • Compatible With HDMI v1.2a (Type A) DVI 1.0 High-Speed Digital Interface
    • Wide Bandwidth of Over 1.65 Gbps (Bandwidth 1.8 Gbps Typ)
    • 165-MHz Speed Operation
    • Serial Data Stream at 10× Pixel Clock Rate
    • Supports All Video Formats up to 1080p and SXGA (1280 × 1024 at 75 Hz)
    • Total Raw Capacity 4.95 Gbps (Single Link)
    • HDCP Compatible
  • Low Crosstalk (XTALK = -41 dB Typ)
  • Low Bit-to-Bit Skew (tsk(o) = 0.2 ns Max)
  • Low and Flat ON-State Resistance (ron = 4 Typ)
  • Low Input/Output Capacitance (CON = 10 pF Typ)
  • Rail-to-Rail Switching on Data I/O Ports (0 to 5 V)
  • VDD Operating Range From 3 V to 3.6 V
  • Ioff Supports Partial-Power-Down Mode Operation
  • Latch-Up Performance Exceeds 100 mA Per JESD 78, Class II
  • ESD Performance Tested Per JESD 22
    • 2000-V Human-Body Model (A114-B, Class II)
    • 1000-V Charged-Device Model (C101)
  • Applications
    • Digital Video Signal Switching
    • Differential DVI, HDMI Signal Multiplexing for Audio/Video Receivers and High-Definition Television (HDTV)
参数 与其它产品相比 特定于协议的开关/多路复用器
Protocols
Configuration
Number of Channels (#)
VCC (Min) (V)
VCC (Max) (V)
Ron (Typ) (Ohms)
Input/Ouput Voltage (Min) (V)
Input/Ouput Voltage (Max) (V)
ICC (Max) (uA)
Bandwidth (MHz)
ESD HBM (Typ) (kV)
Operating Temperature Range (C)
Package Size: mm2:W x L (PKG)
Package Group
Crosstalk (dB)
ESD Charged Device Model (kV)
ICC (Typ) (uA)
Input/Output Continuous Current (Max) (mA)
Input/Output OFF-state Capacitance (Typ) (pF)
Input/Output ON-state Capacitance (Typ) (pF)
OFF-state leakage current (Max) (µA)
Propagation Delay (ns)
Ron (Max) (Ohms)
Ron Channel Match (Max) (Ω)
RON Flatness (Typ) (Ohms)
Turn off Time (Disable) (Max) (ns)
Turn on Time (Enable) (Max) (ns)
VIH (Min) (V)
VIL (Max) (V)
TS3DV416 TS3DV20812 TS3DV421 TS3L4892
HDMI
DVI
LVDS
HDMI
DVI
LVD
VGA
LAN
HDMI
DVI
LVDS
TMDS
VGA
SXGA
10 BASE-T
100 BASE-T
1000 BASE-T
LVDS
LAN
2:1 SPDT     2:1 SPDT     2:1 SPDT     2:1 SPDT
8     11     8     11
3     2.25     1.5     3
3.6     3.6     3.6     3.6
4     4     12.5     4
0     0     0     0
5.5     5.5     3.6     3.6
600     500     450     500
900     1100     1900     1100
2     2     2     2
-40 to 85     -40 to 85     -40 to 85     -40 to 85
48TSSOP: 101 mm2: 8.1 x 12.5(TSSOP)
48TVSOP: 62 mm2: 6.4 x 9.7(TVSOP)
36VQFN: 36 mm2: 6 x 6(VQFN)     48TVSOP: 62 mm2: 6.4 x 9.7(TVSOP)
42WQFN: 32 mm2: 3.5 x 9(WQFN)
TSSOP
TVSOP
VQFN     TVSOP
WQFN
VQFN
-41     -95
1     1     1     1
250       230     250
128     128     100     128
3.5     8     1     2.5
10     2.5     4     8
1     1     1
0.04     0.149     0.25     0.04
8     6     20     6
0.2     1     0.2     1
0.7     0.4     0.5     0.5
8.5     18     5     9
11.5     17     9     15
2     2     1.4     2
0.8     0.8     0.5     0.8
技术文档
数据手册(1)
元器件购买 TS3DV416 相关库存
